I want to change the grub2 menu color to black and white, also if it's related I wanted to change the purple color that appear between transitions when the PC boot.
I'm using Ubuntu 15.04.
Tim
  • 33,500
Duarte Azevedo
  • 99
Instead of changing the background color, you could make an image the background.
Choose a PNG image, copy it, open terminal, run the command sudo nautilus /boot/grub, input password and Nautilus (Ubuntu explorer) will be opened. Paste your image in the folder you were redirected to.
Open a new Terminal window, run sudo update-grub, wait for the process to end and reboot your computer. The chosen image should be your GRUB background then.
About the letters' color, it will be the perfect opposite of the background color.
So, if you want a black background, you could use this image.
Eduardo Cola
  • 5,876
  • 20
  • 33
I would recommend checking out the site here.
http://ubuntuhandbook.org/index.php/2014/04/install-grub-customizer-ubuntu-1404/
But if you want the command for the program suggested in website, it is here:
The program is called Grub Customizer and I have used it before and recommend it. Or moving to another boot loader is good too, which I can help you on too.
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
Good Luck and ask for help if needed.
Apad121
  • 443
  • 19
