29
I have a ton of files, all named stuff like 1.jpg, 2.jpg, 3.jpg, and so on up to 1439.jpg, however, I have a problem with one of my projects and alphabetizing. It will usually go in the order 1.jpg, 10.jpg, 11.jpg and so on.
What I need is some way to name the files so they are in the format such as 00001.jpg all the way up to 01439.jpg.
How would I be able to do this quickly and efficiently?
Oli
  • 299,380
Kaz Wolfe
  • 34,680
9 Answers9
40
Ubuntu comes with a script called rename. It's just a little Perl script that features a number of powerful bulk-renaming features but the best (in this case) is the ability for it to run Perl during the replacement. The result is a truly compact solution:
rename 's/\d+/sprintf("%05d", $&)/e' *.jpg
This is similar to the other printf-style answers here but it's all handled for us. The code above is for a 5-digit number (including a variable number of leading zeros).
It will search and replace the first number-string it finds with a zero-padded version and leave the rest of the filename alone. This means you don't have to worry too much about carrying any extension or prefix over.
Note: this is not completely portable. Many distributions use rename.ul from the util-linux package as their default rename binary. This is a significantly stunted alternative (see man rename.ul) which won't understand the above. If you'd like this on a platform that isn't using Perl's rename, find out how to install that first.
And here's a test harness:
$ ls
$ rename 's/\d+/sprintf("%05d", $&)/e' *.jpg
$ ls
And an example prefixes (we aren't doing anything different):
$ touch track_{9..11}.mp3 && ls
track_10.mp3  track_11.mp3  track_9.mp3
$ rename 's/\d+/sprintf("%02d", $&)/e' *.mp3 && ls
track_09.mp3  track_10.mp3  track_11.mp3
Oli
  • 299,380
22
for f in *.jpg ; do if [[ $f =~ [0-9]+\. ]] ; then  mv $f `printf "%.5d" "${f%.*}"`.jpg  ; fi ; done
Edit
Explanation:
  • if [[ $f =~ [0-9]+\. ]] makes sure that only files whose names are numbers (followed by a dot) are being renamed.
  • printf "%.5d" NUMBER adds the leading zeroes
  • "${f%.*}" cuts the extension (.jpg) and leaves just the number
  • .jpgafter the second backtick adds the file extension again.
Note that this will work only on file names that are numbers. Left-padding leading zeroes to non-numbered files would require different format.
If you want to experiment try this command:
for f in *.jpg ; do if [[ $f =~ [0-9]+\. ]] ; then echo mv $f `printf "%.5d" "${f%.*}"`.jpg  ; fi ; done
Edit 2
Made the command safer by making sure that only file names that are numbers are being renamed. Note that any pre-existing files named like 00001.jpg will be overwritten.
sмurf
  • 4,750
  • 26
  • 30
10
Below a python script.
The script adds leading zeros up to the defined number of digits. If the name is larger than that, the file(name) is untouched.
Combining different extensions in one rename action might add some convenience. To add extension(s), simply add them to the tuple, for example extensions = (".jpg", ".jpeg", ".tiff").
Copy the text into an empty file, save it as rename.py, enter the correct path to the files directory (sourcedir), the number of digits you'd like the new names to have (number_ofdigits) and the file extension(s) to rename (extensions)
Run it by the command:
python3 /path/to/script/rename.py
The script:
#!/usr/bin/python3
import shutil
import os
sourcedir = "/path/to/files"; number_ofdigits = 5; extensions = (".jpg", ".jpeg")
files = os.listdir(sourcedir)
for item in files:
    if item.endswith(extensions):
        name = item.split("."); zeros = number_ofdigits-len(name[0])
        newname = str(zeros*"0")+name[0]+"."+name[1]
        shutil.move(sourcedir+"/"+item, sourcedir+"/"+newname)
edit:
Below a slightly improved version. It automatically determines the longest name in the directory, and adds leading zeros up to the length of the longest name.
example:
becomes:
No need to set the number of digits.
#!/usr/bin/python3
import shutil
import os
sourcedir = "/path/to/files"; extensions = (".jpg", ".jpeg")
files = [(f, f[f.rfind("."):], f[:f.rfind(".")]) for f in os.listdir(sourcedir)if f.endswith(extensions)]
maxlen = len(max([f[2] for f in files], key = len))
for item in files:
    zeros = maxlen-len(item[2])
    shutil.move(sourcedir+"/"+item[0], sourcedir+"/"+str(zeros*"0")+item[0])
Jacob Vlijm
  • 85,475
There is a rename utility implemented in Perl that makes this very easy:
rename 's/\d+/sprintf("%05d",$&)/e' *.jpg
The first argument is a Perl expression that is evaluated for each file name.
If by any chance your rename command is not perl-rename, you can use this perl code:
foreach (<*.jpg>) { rename $_, sprintf("%03d.jpg", $1) if /^(\d+).jpg/; }
When we say foreach we can refer to the files by $_
But you can install the propper perl-rename with this commands
cpan
cpan1> install File::Rename
Another way of renaming these files easily is opening the folder with ranger file manager, select all files, run :bulkrename and use this vim command:
:%s/^\d\+/\=printf("%03d", submatch(0))
I have also tried using ls + awk
ls -1 | awk -F. '{printf "%s%s%s%03d.%s\n", "mv ", $0, " ", $1, $2}'
Each string or number must be associated on the printf function, the result output will be something like this:
To really perform the renaming with this you have to add | sh at the end of it:
ls -1 | awk -F. '{printf "%s%s%s%03d.%s\n", "mv ", $0, " ", $1, $2}' | sh
The zsh shell has a loadable zmv module, similar to the external mmv command, and it also supports numeric ranges <m-n> in its shell globs. So for instance given:
 % ls *.mp4
'3 - Ariane Rocket Disaster.mp4'           '81 - Proof of Guarantee (Sketch).mp4'
'39 - Conditions Example.mp4'              '82 - Measured vs. Worst-Case Probability.mp4'
'396 - Execution Path of a Program.mp4'    '86 - Coverage of Random Testing.mp4'
'397 - Computation Tree Example.mp4'       '88 - Intro to Automated Test Generation.mp4'
'398 - Existing Approach I.mp4'            '89 - Outline.mp4'
'399 - Existing Approach II.mp4'           '9 - Program Invariants.mp4'
'400 -  Combined Approach.mp4'             '90 - Korat.mp4'
'401 - An Illustrative Example .mp4'       '91 - The Problem.mp4'
'402 - Computation Tree.mp4'               '92 - An Insight.mp4'
'403 - Computation Tree Solution.mp4'      '94 - Scheme for Representing Shapes.mp4'
'7 - Dynamic Program Analysis.mp4'         '95 - Representing Shapes.mp4'
'78 - Concurrency Bug Depth Solution.mp4'  '96 - Representing Shapes Solution.mp4'
'79 - Cuzz Algorithm.mp4'                  '97 - A Simple Algorithm.mp4'
'8 - Static Program Analysis.mp4'          '98 - Enumerating Shapes.mp4'
'80 - Probabilistic Guarantee.mp4'         '99 - Enumerating Shapes Solution.mp4'
then once the module is loaded as
 % autoload -Uz zmv
you can do
 % zmv -n '(<1-99>) - (*.mp4)' '${(l:3::0:)1} - ${2}'
mv -- '3 - Ariane Rocket Disaster.mp4' '003 - Ariane Rocket Disaster.mp4'
mv -- '39 - Conditions Example.mp4' '039 - Conditions Example.mp4'
mv -- '7 - Dynamic Program Analysis.mp4' '007 - Dynamic Program Analysis.mp4'
mv -- '78 - Concurrency Bug Depth Solution.mp4' '078 - Concurrency Bug Depth Solution.mp4'
mv -- '79 - Cuzz Algorithm.mp4' '079 - Cuzz Algorithm.mp4'
mv -- '8 - Static Program Analysis.mp4' '008 - Static Program Analysis.mp4'
mv -- '80 - Probabilistic Guarantee.mp4' '080 - Probabilistic Guarantee.mp4'
mv -- '81 - Proof of Guarantee (Sketch).mp4' '081 - Proof of Guarantee (Sketch).mp4'
mv -- '82 - Measured vs. Worst-Case Probability.mp4' '082 - Measured vs. Worst-Case Probability.mp4'
mv -- '86 - Coverage of Random Testing.mp4' '086 - Coverage of Random Testing.mp4'
mv -- '88 - Intro to Automated Test Generation.mp4' '088 - Intro to Automated Test Generation.mp4'
mv -- '89 - Outline.mp4' '089 - Outline.mp4'
mv -- '9 - Program Invariants.mp4' '009 - Program Invariants.mp4'
mv -- '90 - Korat.mp4' '090 - Korat.mp4'
mv -- '91 - The Problem.mp4' '091 - The Problem.mp4'
mv -- '92 - An Insight.mp4' '092 - An Insight.mp4'
mv -- '94 - Scheme for Representing Shapes.mp4' '094 - Scheme for Representing Shapes.mp4'
mv -- '95 - Representing Shapes.mp4' '095 - Representing Shapes.mp4'
mv -- '96 - Representing Shapes Solution.mp4' '096 - Representing Shapes Solution.mp4'
mv -- '97 - A Simple Algorithm.mp4' '097 - A Simple Algorithm.mp4'
mv -- '98 - Enumerating Shapes.mp4' '098 - Enumerating Shapes.mp4'
mv -- '99 - Enumerating Shapes Solution.mp4' '099 - Enumerating Shapes Solution.mp4'
where (l:3::0:) in the replacement variable expansion is a modifier that left pads to width 3 using string 0.
Remove the -n flag once you are happy with the proposed renamings.
steeldriver
  • 142,475
I just found that simply putting all the numbered files without extensions in a folder - then using the Ubuntu FILES GUI "select all" - then you can actually right click and "rename" them all - just put in ".jpg" after the [original filename] box - pretty simply. I was impressed.
There is a GUI that will do this called pyRenamer which can be found in the repositories. Install, start, select your directory and just set the 'Renamed file name pattern' to '{num5}'on the 'Patterns' tab and click the 'Rename' button. You can also preview what will happen prior to renaming.
user287888
for file in `(find * -maxdepth 1 -type f -name "*.jpg")`
do
  mv $file "000"$file
done
This is crude, since it doesn't do the renaming intelligently, will need to think of a trick for that. But it should help you sort stuff.
Update: Well you have a more complete answer.
