10
I used Sound Juicer to rip a CD of audio for a language learning book so that I could listen to them on my Android. However, Sound Juicer seems to only have the option of numbering files without leading zeros. Like this:
track_1.mp3
track_10.mp3
track_11.mp3
This leads to some confused ordering on my music player. So, I want to add some zeros to the name, so that they're ordered properly, like this:
track_01.mp3
track_02.mp3
track_03.mp3
How do I accomplish this? I tried using GPRename, but while it has the ability to add numbers, it doesn't seem to have any options for adding leading zeros.
Is there a better program or something I can do at the command line?
guntbert
  • 13,475
Questioner
  • 6,959
5 Answers5
10
I'm assuming that you just need to rename the files 1-9, since those are the ones that need padding. There are multiple ways of doing this.
You can execute the below command:
for n in $(seq 9); do mv track_$n.mp3 track_0$n.mp3; done;
This will rename tracks track_1.mp3 - track_9.mp3 to track_01.mp3 - track_09.mp3.
To break it down, it looks like this:
for n in $(seq 9)
do
done
  • for n in $(seq 9): for every number in the output of the command seq 9, which is a command that just lists numbers 1 to 9, do,
  • mv track_$n.mp3 track_0$n.mp3: this is the actual command that renames the files. It substitutes the value of n iterating through all numbers. So it does mv track_1.mp3 track_01.mp3, mv track_2.mp3 track_02.mp3, until that last number which is 9.
Alaa Ali
  • 32,213
The script below wil rename files is given directory. It calculates the number of leading zeros needed, no matter the number of files (if >100, more zeros are needed), and renames the files automatically.
To use it
copy the script below into an empty file, in the headsection, set the sourcedirectory, the prefix ("track-" in this case) and the file extension of the files you want to rename. Save it as rename.py and run it by the command:
python3 /path/to/script.py
The script:
#!/usr/bin/env python3
import shutil
import os
sourcedir = "/path/to/sourcedir"
prefix = "track_"
extension = "mp3"
files = [(f, f[f.rfind("."):], f[:f.rfind(".")].replace(prefix, "")) for f in os.listdir(sourcedir) if f.endswith(extension)]
maxlen = len(max([f[2] for f in files], key = len))
for item in files:
    zeros = maxlen - len(item[2])
    shutil.move(sourcedir+"/"+item[0], sourcedir+"/"+prefix+str(zeros*"0"+item[2])+item[1])
muru
  • 207,228
Jacob Vlijm
  • 85,475
Of course there are many ways of doing it. You can, for instance:
  • Separate the parts
  • pad the part that has the number
  • concatenate the individual part back to the new name
Put this into a loop:
#!/bin/bash
item="track_1.mp3"
part1=`echo $item | awk -F_ '{print $1}'`
part2=`echo $item | awk -F_ '{print $2}'`
part2a=`echo $part2 | awk -F. '{print $1}'`
part2b=`echo $part2 | awk -F. '{print $2}'`
number=`printf "%02d" $part2a`
seperator="_"
newname="$part1$seperator$number.$part2b"
echo $newname
The loop:
#!/bin/bash
for item in track_1.mp3 track_10.mp3 track_11.mp3
do
    seperator="_"
    echo "Renaming $item -> $newname"
    mv $item $newname
done
enter code here
L. D. James
  • 25,444
Make a script that will work like a command.
Make this file on the directory where you track file exist.
  • Do like this
    touch change
    chmod +x change
    vim change
  • In it write
    #!/bin/bash
    n=0
    for m in {00 .. 99}
    do
       mv track_$n.mp3 track_$m
       n=`expr $n + 1``
    done
Doorknob
  • 378
GPRename will automatically insert a zero if you are renaming 10 or more files (two if you are renaming 100 or more, etc.) when using the numerical function. Just make sure Zero auto-fill is turned on in the Options menu.
Fern Moss
  • 8,925
