I found an answer for zero-padding numerical filenames which works fine for renaming filenames as follows :
That uses the following command:
rename 's/\d+/sprintf("%05d", $&)/e' *.jpg
But my filenames aren't numeric. They are an alphanumeric sequence, like: a.jpg, b.jpg, c.jpg...... m.jpg.
In a similar way to the original question, I want to rename these so they display in the correct sequence. How do I do this?
You can zero-pad letters too, you just need to alter my original command slightly to:
rename 's/\w+/sprintf("%05s", $&)/e' *.jpg
We're basically just saying, replace the first "word" (numbers and letters) with a zero-padded string. It's very similar to the original, it's just slightly different. This version wold work for the original problem.
You could expand it into a .+ match (to zero pad everything), but then you might need to handle the extension on top.
Test harness:
$ rename 's/\w+/sprintf("%05s", $&)/e' *.jpg
$ ls
Oli
  • 299,380
