29
I tried to use this tutorial to make scroll switch work on my Microsoft Natural Ergonomic Keyboard 4000. But I face following error:
sudo: /lib/udev/keymap: command not found
I have udev version 204-5ubuntu20.2 (the version found in Trusty)
I noticed that this version doesn't include keymap tool. But I notices that greater udev versions (which available for Debian, for example) include this tool.
Could somebody explain this diff for me? =) And what should I do in this case - install package from Debian repo?
matanox
  • 1,861
5 Answers5
38
Ubuntu 15.10: I had no success with previous answers.
I have successfully used approach similar to the previous ones - instructions were mentioned in /lib/udev/hwdb.d/60-keyboard.hwdb.
I've created new hwdb file using sudo nano /etc/udev/hwdb.d/70-keyboard.hwdb containing:
# Microsoft Natural Ergonomic Keyboard 4000 - remap zoom in/out to page up/down
evdev:input:b0003v045Ep00DB*
 KEYBOARD_KEY_c022d=pageup
 KEYBOARD_KEY_c022e=pagedown
after that I've run
sudo udevadm hwdb --update
sudo udevadm control --reload
and replugged the keyboard and it worked.
For model 7000 use evdev:input:b003v045Ep071D*
28
If you look at /lib/udev/rules.d/60-keyboard.rules you'll see that everything has been messed around with. This is just part of the udev merger into systemd that has gone on.
All hardware rules are compiled into a binary hardware database. These follow a really strange format. The existing rules for keyboards that ship with udev live in /lib/udev/hwdb.d/60-keyboard.hwdb. Look at that but don't edit it (updates will probably overwrite it).
To add your custom rules, we'll create a new file in /etc/udev/hwdb.d/ by running sudoedit /etc/udev/hwdb.d/61-keyboard-local.hwdb. All you need to do is paste in the following -
If you are using the 4000 model:
keyboard:usb:v045Ep00DB*
 KEYBOARD_KEY_0c022d=pageup
 KEYBOARD_KEY_0c022e=pagedown
If you are using 7000 model:
keyboard:usb:v045Ep071D*
This is adapated from the tutorial you posted so you might need to tweak based on your keyboard. Look at lsusb and make sure the vendor:product code above (as v####p####) is correct. It won't work if they don't match.
Once you're done editing, recompile the hwdb that udev uses:
And then you might need to re-plug. If it's a PS/2 keyboard you might need to reboot. In some cases you also need to reboot.
matanox
  • 1,861
Oli
  • 299,380
The original solution posted by Oli did not work for me, but it works after I changed the key numbers "0c022d" and "0c022e" to "c022d" and "c022e". I'm using a 4000 model, so I can't verify if the same change is needed for the 7000 model.
To repeat Oli's answer, here is what I did: create a new file by running sudo nano /etc/udev/hwdb.d/61-keyboard-local.hwdb. Paste the following lines to the file (for the 4000 model):
After editing the file, recompile the hwdb that udev uses:
Then replug the keyboard.
Adding to Oli's answer, If you want line scrolling like how it is on a mouse, you can modify pageup/pagedown to up/down in your custom rule. Like:
 KEYBOARD_KEY_c022d=up
 KEYBOARD_KEY_c022e=down
r11
  • 73
Nice solution is here, and I can only add that you can map the keys to unused X keys like that:
$ cat /lib/udev/rules.d/95-keymap.rules
ENV{ID_VENDOR}=="Microsoft", ENV{ID_MODEL_ID}=="00db", RUN+="keymap $name 0xc022d katakana 0xc022e katakanahiragana
Proper names to use instead of katakana can be found here.
After reboot ;-) you can test that zoomin and zoomout keys are mapped successfully, and also to find out a proper names of the keys (to use in rc.xml for OpenBox WM, for example) using xev:
$ xev
KeyRelease event, serial 46, synthetic NO, window 0x3c00001,
    root 0x291, subw 0x0, time 1492891, (-261,-61), root:(573,380),
    state 0x0, keycode 101 (keysym 0xff27, Hiragana_Katakana), same_screen YES,
    XLookupString gives 0 bytes:
    XFilterEvent returns: False
Now you can connect new keys to completely arbitrary action. In my case of OpenBox window manager I used something like this:
$ cat <whatever>/rc.xml
<keybind key="Katakana">
  <action name="Execute">
    <command>volume_up.sh</command>
  </action>
</keybind>
<keybind key="Hiragana_Katakana">
    <command>volume_down.sh</command>
  </action>
</keybind>
