21
I use a Microsoft Natural Ergonomic Keyboard 4000 on Ubuntu 10.10. The multimedia keys (Volume, Play/Pause) work, the Mail and Calculator button as well.
Now I would love to use the zoom slider, if it were possible I'd like to use page scrolling with that. Is there some way to enable that?
Braiam
  • 69,112
5 Answers5
18
Create the file /etc/udev/rules.d/98-ms-ergo.rules with the following contents:
ACTION=="remove", GOTO="keyboard_end"
KERNEL!="event*", GOTO="keyboard_end"
ENV{ID_INPUT_KEY}=="", GOTO="keyboard_end"
SUBSYSTEMS!="usb", GOTO="keyboard_end"
SUBSYSTEMS=="usb", IMPORT{builtin}="usb_id"
ENV{ID_VENDOR}=="Microsoft", ENV{ID_MODEL_ID}=="00db", RUN+="keymap $name 0xc022d pageup 0xc022e pagedown"
GOTO="keyboard_end"
This will map the zoom key to page-up/page-down without changing the installed files in /lib/udev.
Once added, you just need to unplug and replug your keyboard for it to start working.
Kees Cook
  • 17,823
10
On Xubuntu 13.10 (perhaps on Ubuntu 13.10 too) the same can be done as follows:
Edit key mappings in /lib/udev/hwdb.d/60-keyboard.hwdb:
# Microsoft
# Microsoft Natural Ergonomic Keyboard 4000
keyboard:usb:v045Ep00DB*
 KEYBOARD_KEY_c022d=pageup
 KEYBOARD_KEY_c022e=pagedown
Run sudo udevadm hwdb --update
Reboot.
In order to configure the Microsoft ergonomic keyboard 4000 we have to create a configuration file that contains the keyboard declaration and the records for mapping the keys.
To do so there are three types of information we need to determine:
  • Keyboard type
  • The key scancode which is the actual key on the keyboard
  • The key name to assign the desired functionality to the selected key
First find the keyboard type:
In terminal run the following command:
lsusb
the output determines the keyboard type:
Bus 004 Device 022: ID 045e:00db Microsoft Corp. Natural Ergonomic Keyboard 4000 V1.0
It appears after ID. In this case it is 045e:00db
Second find the scancode and the name of the key.
To determine them, we use the evtest program which logs out the event information of a specific device on terminal:
evtest
If you don't have the program, install it by running the following command:
sudo apt-get install evtest
By running the evtest program we get the following output:
No device specified, trying to scan all of /dev/input/event* Available devices:
/dev/input/event0:    Power Button
/dev/input/event1:    Power Button
/dev/input/event2:    PixArt USB Optical Mouse
/dev/input/event3:    Microsoft NaturalĀ® Ergonomic Keyboard 4000
/dev/input/event4:    Microsoft NaturalĀ® Ergonomic Keyboard 4000
/dev/input/event5:    HDA Intel Front Headphone
/dev/input/event6:    HDA Intel Line Out
/dev/input/event7:    HDA Intel Line
/dev/input/event8:    HDA Intel Rear Mic
/dev/input/event9:    HDA Intel Front Mic
/dev/input/event10:   HDA ATI HDMI HDMI/DP,pcm=3
Select the device event number [0-10]:
The output is pretty much self explanatory, insert the appropriate number for the keyboard, which here is number 3 then hit enter:
Doing so, will output lots of information on the terminal and ends in following lines:
Testing ... (interrupt to exit)
Event: time 1472203902.240594, type 17 (EV_LED), code 0 (LED_NUML), value 0
Event: time 1472203902.240594, -------------- SYN_REPORT ------------
Event: time 1472203902.281456, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70058
Event: time 1472203902.281456, type 1 (EV_KEY), code 96 (KEY_KPENTER), value 0
Event: time 1472203902.281456, -------------- SYN_REPORT ------------
Now with every key-press on the keyboard it dumps out the key information. For example the Slash key next to the Right Shift shows:
Event: time 1472205062.294078, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70038
Event: time 1472205062.294078, type 1 (EV_KEY), code 12 (KEY_SLASH), value 0
Event: time 1472205062.294078, -------------- SYN_REPORT ------------
The first line of the log contains the information about the actual key on the keyboard such as scancode which comes after the value. In this case it is 70038
The second line contains the assigned functionality information like name of the key. In this case it is SLASH. Examine the other keys to find their appropriate names.
So in a nutshell:
  • Our keyboard type is: 045e:00db
  • The scancode of the Slash key is: 70038
  • The name of the key for assigning is SLASH
After gathering the necessary information we create the configuration file:
sudoedit /etc/udev/hwdb.d/61-keyboard-local.hwdb
Hit i to activate the Insert mode and type the following:
 KEYBOARD_KEY_70038=minus
Save and exit by pressing escape then typing :wq and hit enter.
Then run the following two commands for the configuration to take effect:
sudo udevadm control --reload
Finally unplug the keyboard and re-plug it in.
Some notes about the configuration file:
  • The format of the file should be exactly as shown, the space before mapping records is critical.
  • Instead of sudoedit you can use any other text editor, just remember to follow the exact format of the file as explained above.
  • There are two characters added to the keyboard type: v and p which stand for vendor and product. They are important as well.
  • The keyboard type is written uppercase in the configuration file. Our keyboard type was 045e:00db but in the configuration we insert v045Ep00DB*
  • The scancode of the key comes right after KEYBOARD_KEY_
  • The key name appears in lowercase in configuration file
  • You can customize pretty much every key on your keyboard following this tutorial.
Kobayashi
  • 195
The problem is that evdev driver ignores keycodes > 255.
The solution, thanks to Marco Chiappero:
1) you have to define all the remappings that you need (in the form of
"scancode keycode" list) and place them in a file under "/lib/udev/keymaps/"
(for example I created logitech-lx710-cordless there). You can find the
scancodes using evtest ("sudo evtest /dev/input/eventX", where X is your
keyboard device. Be careful, sometimes these extra keys are exposed through
a different device or your mouse interface: eg. event3 --> kbd, event4 -->
mouse & extra keys). Here some sample output:
Event: time 1294153475.909379, type 4 (Misc), code 4 (ScanCode), value c1028
"c1028" is the scancode value you're going to place in your keymap file, then
pick up a number from input.h as described earlier and convert it to
hexadecimal. Then write the remap pair in your file, maybe with a descriptive
comment, like this:
0xC1028 0x9a # rotate button
Iterate for every key > 255.
2) you have to tell udev to apply this remapping file everytime it encounters
your keyboard, so edit the "/lib/udev/rules.d/95-keymap.rules" file adding
the udev rule that matches your HW. Please don't ask me to define a rule for
you.
NOTE: you can immediately apply your keymap file by yourself typing
"sudo /lib/udev/keymap /dev/input/eventX /lib/udev/keymaps/$YOUR_FILE" and
verify it with evtest once again.
Now, you can use the Gnome shortcuts editor to see that the keys are now
usable inside X and create new shortcuts. However it might happen that no
keysym is assigned to that keycode (so you'll see 0xXY instead of XF86Foo).
You can see current mappings through xmodmap -pke, save the output into a
file and edit it if you need (a full keysym code list is available in
"/usr/lib/X11/XKeysymDB").
Once you added the keysyms to those keys you remapped, you can save this file
as ~/.Xmodmap (or as /etc/X11/Xmodmap if you wish to apply to every user).
desgua
  • 33,215
On my machine, extra keys (HomePage, Search, Calc, etc.) and zoom input were sent though /dev/input/event5 whereas ordinary keys were sent through /dev/input/event4. Zoom key value agree with queueoverflow's.
niclas
