161
How do you show a hidden folder (whose name starts with .) in File Manager a.k.a. Nautilus on Ubuntu? I am somewhat new to Ubuntu and can't seem to find the "view" menu.
Kulfy
  • 18,154
Strato1
  • 2,190
8 Answers8
180
Ubuntu 17.10 and earlier
Maximize the folder.
Go to the top menu -->View->Show hidden files:
Or by pressing ctrl + H.
For permanently showing hidden files, you can go to the Edit>Preferences menu item as shown below:
preferences
With the terminal you should:
cd /path-of-directory
ls -a
Dan
  • 14,180
nux
  • 39,152
43
Ubuntu 18.04
The accepted answer is correct for older versions of Ubuntu.
In the top right corner of file explorer, there is a menu button displayed as 3 stacked line (hamburger menu), clicking on that will open a modal, on that there is an option Show hidden files
Image 1
sotirov
  • 4,379
Ubuntu 20.04/ 21.04/ 21.10
Using the Nautilus option Show hidden files will only resolve the issue temporarily, but there are ways to set this as the default option.
Terminal
There is a nice one-liner to do this:
gsettings set org.gnome.nautilus.preferences show-hidden-files true
The settings will take effect immediately (even for currently running instances). You can check current value with:
gsettings get org.gnome.nautilus.preferences show-hidden-files
with GUI
As posted above you may install dconf-editor
sudo apt install dconf-editor
Then search for show-hidden and activate the option org.gnome.nautilus.preferences.
As you can see in the following screenshot the "same" option also exists for other applications such as the Gtk FileChooser, so make sure you activate the setting where you need it. dconf-editor will also show you the key to use for each setting in case you want to set it using gsettings as outlined in the first section of this post.
dconf editor search result
LFischer
Ubuntu 20.04
For Ubuntu 20.04, the UI is updated to show hidden files. I could see hidden files even after closing and re-opening the application. enter image description here
sotirov
  • 4,379
Ubuntu 24.04
  1. Click on the three-line menu icon (often called the hamburger menu) in the top right corner.
  2. Select "Show Hidden Files" from the dropdown menu.
Show Hidden Files Screenshot
Keyboard Shortcut
Pressing Ctrl + H on your keyboard will toggle the visibility of the hidden files.
From Terminal
gsettings set org.gtk.gtk4.Settings.FileChooser show-hidden true
sotirov
  • 4,379
Ubuntu 23.10
You can use the following command. It works right away and persists:
sotirov
  • 4,379
Rd2023
enter image description hereits really simple
In Ubuntu 18.04, show hidden files is here as shown in the image above...
Isn't it simple
Enjoy!
I found a simple solution for permanently showing hidden files by default.
Using dconf-editor you can search files and toggle the desired setting:
Search for files in dconf-editor
Greenonline
  • 2,182
Neveh
  • 101
