On login the password is accepted but I'm returned to the login screen. Tried multiple times even after reboot... same behavior.
I left my laptop (Lenovo Ideapad z510) in suspend mode (lid down) last night, but it did not resume this morning, as it usually does. It had shutdown or crashed, and on booting with Ubuntu the login failure mentioned above started.
cat ~/.xsession-errors
/usr/sbin/lightdm-session: 1: /usr/sbin/lightdm-session: ls: not found
/usr/sbin/lightdm-session: 104: exec: gnome-session: not found
Okay. I've tried a bunch of suggestions from Ubuntu gets stuck in a login loop
- Changed
idto/usr/sbin/idin/etc/profile - removed
.Xauthority - removed
/tmp - removed, purged and re-installed lightdm
- checked
.profilefor syntax errors (source .profileworked fine, so I guess no syntax errors)
Nothing worked.
My guest login is working fine, so another user should also work. I'm now going to create another user and continue working, but a solution to this problem is still warranted... it's likely going to repeat in future.
Installing and reconfiguring gdm also did not work.
sudo apt-get install gdm
