I can't login through GUI on Ubuntu version 16.04. This problem occurred after installing JDK 8 and Scala/SBT (if I remember correctly, it was needed to declare paths for Java or something).
I have already tried the 3 usual fixes for this problem and I've also tried editing / looking for possible syntax errors on files like .profile (I can't really get my head around how all these files interact with each others, I'm really new to Linux).
This is text from .xsession-errors:
/usr/sbin/lightdm-session: line 24: mktemp: command not found
/usr/sbin/lightdm-session: line 29: : No such file or directory
/usr/sbin/lightdm-session: line 33: cat: command not found
/usr/sbin/lightdm-session: line 34: truncate: command not found
/usr/sbin/lightdm-session: line 106: ls: command not found
/usr/sbin/lightdm-session: line 117: exec: gnome-session: not found
Also, I'm really sorry for the lack of information provided here since I don't really know what should I provide here.
Ravexina
  • 57,256
nhohn
I think I know what your problem here is: Your PATH is broken.
From your question:
Have you modified your PATH variable settings?
And if so, how did you set/modify the PATH variable?
To confirm, log on to a virtual console (CTRL,ALT,F1 key sequence), enter your logon details and then run:
printenv PATH
See what you get. If its' broken, undo any changes you made to configuration files such as /etc/environment and entries under /etc/profile , and confirm if this fixes the issue you're experiencing.
