Since last week I'm also faced with the endless-loop problem using ubuntu 14.04.3 (installed in dual-boot on HP 840 EliteBook). Upon login the screen turns black and returns to the login interface.I have investigated a couple of things, but I am really stuck. Thus, I would appreciate, if someone could help me out. I have read most of the existing threads, but it seems that most problems were related to certain typos, e.g.
The output of my .xsession-errors is:
/usr/sbin/lightdm-session: line 33: cat: command not found
/usr/sbin/lightdm-session: line 34: truncate: command not found
/usr/sbin/lightdm-session: line 106: ls: command not found
/usr/sbin/lightdm-session: line 117: exec: gnome-session not found
/etc/profile and ~/.bashrc seem to be working fine. When adding 'echo $PATH' to the end of each file, I get following output:
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
But after logging into tty-console, the output of the $PATH environment variable is actually empty.
Moreover, I have tried:
- renaming/removing .Xauthority
- removing/re-installing/reconfiguring lightdm
- switching to gdm
- reinstalling xorg
- xorg
- adding a new user,
but the endless-loop effect remained. In addition, I've checked:
- permissions of tmp (drwxrwxrwt)
- /etc/environment (contains same path as $PATH above)
- /var/log/lightdm/lightdm.log (file is empty)
- .pam_environment (this file does not exist so nothing can be wrong here)
Since I am rather new to ubuntu, I would be grateful for some hints. Thanks in advance for your efforts!
