I'm new to Linux world and I have a problem with my fresh installation of Ubuntu 14.10 64-bit. My processor is Intel® Pentium(R) D CPU 2.80GHz × 2 with 4 GB of ram and GeForce 8600 GT/PCIe/SSE2. When I use PC CPU load is always above 0.90.
I found these questions but no luck at all with finding solution:
In terminal top Xorg and Compiz are always first. For example while I'm moving Firefox window both go around 60% of CPU or when I open the search menu and typing random stuff.
In Unity Tweak Tool texture quality is on fast and all animations are disabled + blur under search windows is turned off, installing Unity 2D doesn't work.
I'm using the NVIDIA Binary Driver 331.38 and changing workspaces is very smooth just like scrolling pages is Firefox.
Also I disabled the hardware acceleration in Firefox and some of the plugins. I have right now turn on Adblock Plus and Flash - block.
I'm not sure but this can help:
sudo dmidecode -t processor | grep Speed
Max Speed: 4000 MHz
Current Speed: 2800 MHz
Also done this.
Copy and paste, or type, the following lines at the bottom of the Screen section:
Option "RenderAccel" "True"
Option "DisableGLXRootClipping" "True"
Option "DamageEvents" "True"
Option "UseEvents" "True"
Then I had to recover the Xorg default settings, when I restarted PC window show up with something like:
You are running low graphics mode
but I fixed it so all is OK right now.
It's 5th day and I'm stuck, so I'm begging for help.
Also I installed XFCE (Xubuntu 14.10) and LXDE (Lubuntu 14.10) but I like Unity much more.
On Ubuntu 14.10 32-bit is even worse + here is my top when PC on idle, all look good:
load average: 0.11, 0.21, 0.29
but PC is for work not idle.
So finally my question: is it normal? If not how can I fix my CPU usage? Why is Xorg and Compiz so resource hungry?
