15
I always have high CPU usage in Ubuntu in every version of it that I have used. I have been using Ubuntu from 10.04 version.
My CPU usage even at idle is more than 30% for each core(unlike Windows 7 uses only 5%) due to which i'm getting my processor under very high temperature. Even my friends too experienced the same problem. This is not solved even now in 13.04. I'm not telling this just by installing Ubuntu in only my system, but I have tested it with single core and multi core processors with and without graphics cards, everything type of configuration gave me the same results.
Someone please help me how to solve this problem, as i'm experiencing this for years.
Currently my system configuration is,
  • AMD Phenom x6 1100t processor
  • AMD Radeon HD 6770 GDDR5 graphics
  • 4GB ram
  • 1TB hdd
Stormvirux
  • 4,536
Murali Krish
  • 151
You first should figure out what process is eating away your CPU.
  • open a terminal with ctrl+alt+t
  • execute the command top
  • note the process using the most cpu
If the process isn't a system process, kill it with sudo pkill [processname] with [processname] the name of the process you want to kill. If it is a system process, don't kill it, but try to google the name of it and figure out what functionality it does in Ubuntu. Then you can proceed to turn it off (in e.g. you system settings).
Joren
  • 5,074
Despite you not having a program open on the desktop there are still scores of processes running on your computer. On Windows you'd use the Task Manager to see which processes are running. On Ubuntu you use the System Monitor (Applications, System Tools, System Monitor). Click on the % CPU column to order by CPU hogs first and you'll soon see which processes are at fault.
Likely candidates:
  1. gnome-system-monitor itself because, well, you're running it and it's doing stuff.
  2. tracker-miner-fs, which is the file indexing service. Go to Applications, System Tools, Preferences, Search and Indexing and select "Only when computer is being used." There's no "off" switch, unfortunately, but you can achieve the same result by moving the "Stop indexing when disk space is below" slider to some really high value.
  3. compiz, which is the desktop compositor. Try going to Applications, System Tools, Preferences, CompizConfig Settings Manager and turning off all of the (probably unnecessary) eye candy.
Even with all your CPU cores pegged at 30% your CPU should not be getting overly hot. Consider clearing any dust from its heat sink and/or upgrading to a better one.
Phoeey
  • 521
I am running Ubuntu 14.04LTS on a Dell Latitude E6400 laptop. I found that disabling the battery charger in the BIOS solves the issue of excessive CPU utilization.
Most likely this was due to excessive current draw (and temperature) by the charger while trying to charge a defective battery.
I tried many of the solutions related to compiz and Xorg utilization but could not solve the problem. Keeping core temperature and speed low seems to solve the problem for me.
See image of CPU temperature under control . (psensor is monitoring the temperature and indicator-cpufreq-selector is selecting the lowest possible core speed of 800MHz.) With this behavior, the system responds very well to user requests. But more interesting, note the core scheduling and utilization at about the same temperature in Turbo (2.40GHz) mode.
Ram
I came here for the same reason, and perhaps found the solution to your question by happenstance. When I launch System Monitor and am on the resources tab, I see 4/4 of my cores randomly spiking from 0 to 50 percent cpu usage. If I click on the File Systems tab for a few seconds, and click back to the Resources tab, I can see that while I was on the File Systems tab, cpu usage flatlined. It could be that the cpu usage you see is simply caused by System Monitor updating the CPU history graph, as appears to be true in my case.
I know answering old threads is frowned upon by many people, but I don't care. I had a current question and google led me to this post, so I assume I am not the only person that will find this post again in the future, and perhaps my answer will help someone else down the road.
