I have upgraded to Ubuntu 14.04. Hp Printer 1020 plus installed but device manager says not found. I cannot print. Can somebody help me out
In fresh 16.04, Ubuntu auto-detected my HP 1020, but it did not work. I ran hp-setup -i (which was preinstalled), and it started working.
Edit: works also for Ubuntu 18.04.
- 1,138
Install some required packages. By copy pasting following code into terminal.
sudo apt-get install hp-ppd printer-driver-hpcups printer-driver-hpijs hpijs-ppds hplip hplip-data hplip-dbg hplip-doc hplip-gui djtools
Now run hp-setup from terminal to add the printer, which will show you a gui from which you can add the printer.
This worked for me on Bodhi Linux (which is Ubuntu 14.04 based). So might work on 14.04 of Xubuntu,Kubuntu,etc.
Note:- It works nicely with KDE too.
Just open the software centre, search for hplip and select "show hidden technical elements (or something like that)". Install hplip and then you'll be able to easily set up your printer
- 368
I installed hplip including the UI. Then opened hplip and pressed the "hammer" button on the toolbar for self diagnosis.
It opened a console that did all the job, I only answered some questions out there. But now it works.
Try with installing HP printer drivers and config packages:
sudo apt-get install hp-ppd hpijs hpijs-ppds hplip hplip-cups hplip-data hplip-dbg hplip-doc hplip-gui djtools
Connect your printer to your PC, and make sure to switch it on,
Then used the command :
hp-doctor
This is a very interactive/easy way to install the printer.
It also installs any missing dependencies.
- 151
Simply open the app manager. Press the search icon. Type hplip. Select hplip. Tap install. Open it. Run the self diagnostics.
- 912
