I have a Compaq cq5115uk dual booted Windows Vista & Ubuntu 14.04 and a HP Laserjet 1020 printer. Under Windows the printer only works if I disable the usb 2.0 devices in Windows device manager leaving only the usb 1.1 devices. Under Ubuntu the printer doesn't work. I'm guessing the problem is the same as Windows, so I'd like to know how to disable usb 2.0 under Ubuntu. Thanks
mike@mike-VC913AA-ABU-CQ5115UK:lsusb
Bus 002 Device 002: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 0461:0010 Primax Electronics, Ltd HP Keyboard
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
How to disable usb 2.0 under Ubuntu?
Try with one feature in the kernel, the ability to bind and unbind drivers from devices manually from user space.
In the sysfs tree, every driver now has bind and unbind files associated with it.
In order to unbind a device from a driver, simply write the bus id of the device to the unbind file.
See more at: Bind-Unbind
kyodake
  • 17,808
