I have read and followed the advice in this question to no avail. I am attempting to install libssl1.0.0:i386 on my 14.04 box (amd64), but when I try to do this via APT, I receive the following error message:
nathan@nathan-desktop:~$ sudo apt-get install libssl1.0.0:i386
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
default-jre-headless : Depends: openjdk-7-jre-headless (>= 7~u3-2.1.1) but it is not going to be installed
openjdk-7-jre : Depends: openjdk-7-jre-headless (= 7u55-2.4.7-1ubuntu1) but it is not going to be installed
Recommends: libgnome2-0 but it is not going to be installed
Recommends: libgnomevfs2-0 but it is not going to be installed
openssh-client : Depends: libssl1.0.0 (>= 1.0.1) but it is not going to be installed
openssh-server : Depends: libssl1.0.0 (>= 1.0.1) but it is not going to be installed
Depends: openssh-sftp-server but it is not going to be installed
Recommends: ssh-import-id but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I have all of the latest updates installed. I have run apt-get -f install. I have made sure that all repositories are enabled in Software Sources.
What could be causing this?
Update:
Here are the contents of apt-cache policy libssl1.0.0:
libssl1.0.0:
Installed: 1.0.1g-1ppa1~trusty1
Candidate: 1.0.1g-1ppa1~trusty1
Version table:
*** 1.0.1g-1ppa1~trusty1 0
100 /var/lib/dpkg/status
1.0.1f-1ubuntu2.1 0
500 http://ca.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
500 http://security.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
1.0.1f-1ubuntu2 0
500 http://ca.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
...and apt-cache policy libssl1.0.0:i386:
libssl1.0.0:i386:
Installed: (none)
Candidate: 1.0.1f-1ubuntu2.1
Version table:
1.0.1f-1ubuntu2.1 0
500 http://ca.archive.ubuntu.com/ubuntu/ trusty-updates/main i386 Packages
500 http://security.ubuntu.com/ubuntu/ trusty-security/main i386 Packages
1.0.1f-1ubuntu2 0
500 http://ca.archive.ubuntu.com/ubuntu/ trusty/main i386 Packages
