17
Ubuntu 14.04 Repositories: universe, main
Ran apt-get update
Ran apt-cache policy libssl1.0.0
ddew@ddew-wsl:~$ apt-cache policy libssl1.0.0
libssl1.0.0:
  Installed: 1.0.1f-1ubuntu2.11
  Candidate: 1.0.1f-1ubuntu2.11
  Version table:
 *** 1.0.1f-1ubuntu2.11 0
        100 /var/lib/dpkg/status
     1.0.1f-1ubuntu2 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
Was surprised to see that the version advertised as the candidate is not the same as what is available from main and that the version available from main is older than the version that is already installed.
Attempted to install libssl-dev
ddew@ddew-wsl:~$ sudo apt-get install libssl-dev
Reading package lists... Done
Building dependency tree
 libssl-dev : Depends: libssl1.0.0 (= 1.0.1f-1ubuntu2) but 1.0.1f-1ubuntu2.11 is to be installed
              Recommends: libssl-doc but it is not going to be installed
Out of curiosity, ran apt-cache policy libssl-dev
ddew@ddew-wsl:~$ apt-cache policy libssl-dev
libssl-dev:
  Installed: (none)
  Version table:
     1.0.1f-1ubuntu2 0
fkraiem
  • 12,813
Doug Dew
  • 171
6 Answers6
22
Same problem on Ubuntu 16.04
libssl1.0.0:
  Installed: 1.0.2g-1ubuntu4.5
  Candidate: 1.0.2g-1ubuntu4.5
  Version table:
 *** 1.0.2g-1ubuntu4.5 100
     1.0.2g-1ubuntu4.1 500
        500 http://mirror.uoregon.edu/ubuntu xenial-updates/main amd64 Packages
        500 http://mirror.uoregon.edu/ubuntu xenial-security/main amd64 Packages
     1.0.2g-1ubuntu4 500
        500 http://mirror.uoregon.edu/ubuntu xenial/main amd64 Packages
libssl-dev:
  Installed: (none)
  Candidate: 1.0.2g-1ubuntu4.1
  Version table:
     1.0.2g-1ubuntu4 500
So I fixed it with
sudo apt-get install libssl1.0.0=1.0.2g-1ubuntu4.1
BHS
  • 321
This worked for me:
Unable to install libssl1.0.0:i386 due to "unmet dependencies"?
sudo apt-get install libssl1.0.0/trusty libssl-dev/trusty openssl/trusty
David Foerster
  • 36,890
  • 56
  • 97
  • 151
vitiral
  • 181
I solved my problem with libssl3:
Problem:
 libssl-dev : Depends: libssl3 (= 3.0.2-0ubuntu1.1) but 3.0.2-0ubuntu1.2 is to be installed
Solution:
I downgraded the libssl3 version
sudo apt install libssl3=3.0.2-0ubuntu1.1
Pilot6
  • 92,041
Update the answer from @BHS for Ubuntu 18.04 in Dec 2018
I got the error
libcurl4-openssl-dev : Conflicts: libssl1.0-dev but 1.0.2n-1ubuntu5.1 is to be installed
Then it fixed with
sudo apt-get install libssl1.0.0=1.0.2n-1ubuntu5.1
thuanle
  • 111
I have solved this problem
 libssl-dev : Depends: libssl3 (= 3.0.2-0ubuntu1) but 3.0.2-0ubuntu1.2 is to be installed
Answer:
Artur Meinild
  • 31,035
This will do:
sudo apt install libssl1.0-dev
Eliah Kagan
  • 119,640
