I'm a newbie on Linux stuff and maybe the solution to my problem is obvious, but I need your help.
I decided to install Kubuntu 14.04 on my laptop (HP pavilion g6-2330sf) and the installation worked perfectly, but even if my Ethernet connection works, the wireless network refuses to be enabled.
So I spent a couple of hours trying to install drivers, NetworkManager etc... but nothing works, or should I say I can't make it work.
When typing the following command in the console $ sudo lshw -C network I get the following output:
*-network
description: Ethernet interface
product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:06:00.0
logical name: eth0
version: 05
serial: 74:46:a0:85:dd:93
capacity: 100Mbits/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=************** (knowingly hidden) latency=0 link=yes multicast=yes port=MII speed=100Mbits/s
resources: irq:46 ioport:2000(size=256) memory:f0204000_f0204fff memory:f0200000-f0203fff
*-network UNCLAIMED
description: Network controller
product: AR9485 Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:07:00.0
version: 01
width:64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory: f0100000-f017ffff memory:f0500000-f050ffff
Furthermore when using the command nmcli nm I get the following output:
RUNNING STATE WIFI-HARDWARE WIFI WWAN-HARDWARE WWAN
running connected enabled disabled enabled disabled
I already read the following Questions:
Wireless networking not working after resume in Ubuntu 14.04
How do I get an Atheros AR9485 wireless card working?
Qualcomm Atheros AR9485 Wireless Network Adapter not working on Ubuntu 13.10
Could someone help me activate the Wireless network?
