Recently i updated my 12.10 ubuntu, ever since i got this strange wifi internet problem. Net works fine on the initial boot, after couple of web requests from a browser or command line or any tool, internet stopped working. I have to disconnect & connect the wifi to get it work again.
It happens every few minutes. Its frustrating. It was working fine before the upgrade. I am sure this is not the machine problem, because my dual boot win 8 works fine.
I tried iwconfig, this is the output
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:"jumbotron"
Mode:Managed Frequency:2.437 GHz Access Point: 08:86:3B:8C:C0:74
Bit Rate=150 Mb/s Tx-Power=16 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=50/70 Signal level=-60 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1 Invalid misc:2 Missed beacon:0
anybody know whats goin on?
Update:
I connected my android phone in wlan and enabled USB tethering with ubuntu machine. It works great.
So the problem is defenitly with wireless configuration or drivers
These are some configs i got
lshw -C network
*-network
description: Wireless interface
product: AR9485 Wireless Network Adapter
vendor: Atheros Communications Inc.
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlan0
version: 01
serial: 00:08:ca:e6:6b:59
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list rom ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=3.2.0-23-generic-pae firmware=N/A ip=192.168.2.11 latency=0 multicast=yes wireless=IEEE 802.11bgn
resources: irq:17 memory:dea00000-dea7ffff memory:dea80000-dea8ffff
ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1727 errors:0 dropped:0 overruns:0 frame:0
TX packets:1727 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:137632 (137.6 KB) TX bytes:137632 (137.6 KB)
wlan0 Link encap:Ethernet HWaddr 00:08:ca:e6:6b:59
inet addr:192.168.2.11 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::208:caff:fee6:6b59/64 Scope:Link
UP BROADCAST MULTICAST MTU:1400 Metric:1
RX packets:12133 errors:0 dropped:0 overruns:0 frame:0
TX packets:11872 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:9352562 (9.3 MB) TX bytes:1851594 (1.8 MB)
nm-tool
NetworkManager Tool
State: connected (global)
- Device: wlan0 [jumbotron] -------------------------------------------------
Type: 802.11 WiFi
Driver: ath9k
State: connected
Default: yes
HW Address: 00:08:CA:E6:6B:59
Capabilities:
Speed: 150 Mb/s
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points (* = current AP)
*jumbotron: Infra, 08:86:3B:8C:C0:74, Freq 2437 MHz, Rate 54 Mb/s, Strength 57 WPA WPA2
IPv4 Settings:
Address: 192.168.2.11
Prefix: 24 (255.255.255.0)
Gateway: 192.168.2.1
DNS: 192.168.2.1
