Solution 1
Hi I recently installed Ubuntu 13.10 on my laptop alongside windows. I have an Atheros AR9485 adapter. It worked well for a few weeks and now won't work anymore although it still works for the windows. I have tried out some of the solutions suggested but it still doesn't work. This so what I have so far done and the answers I get;
$ sudo modprobe -r iwlwifi
Error: missing module name.
FATAL: Error running remove command for iwlwifi
$ sudo modprobe -r iwlwifi.conf
FATAL: Module iwlwifi.conf not found.
$ cd /etc
/etc$ ls
Here I find the directory modprobe.d but modprobe does not exist so I try
$ cd modprobe.d
modprobe.d: No such file or directory
Then I go back to the /etc and try
$ cd /etc
$ cd modprobe.d
/etc/modprobe.d$ ls
I find the file iwlwifi.conf~ and try:
/etc/modprobe.d$ sudo modprobe -r iwlwifi.conf~
FATAL: Module iwlwifi.conf~ not found.
/etc/modprobe.d$ cd ~
$ sudo modprobe.d -r iwlwifi.conf~
sudo: modprobe.d: command not found
I had read a solution that was giving the steps below if I had succeeded. I tried to look for the .conf file and edited it as directed in the last part of this solution but it didn't work and I was unable to go beyond that;
Looks like this hardware has some problem with N configuration in WiFi. Please try:
sudo modprobe iwlwifi 11n_disable=1
Now try to reconnect, if it helps follow below steps
Look into
/etc/modprobe.dwhether there are any file likeintel-5100-iwlwifi-disable11n.confthen edit the file.sudo gedit /etc/modprobe.d/<filename_here>Edit the line that says
options iwlwifi 11n_disable=1to
options iwlwifi 11n_disable=0Save and reboot.
If no file exists, create a new file
gksudo gedit /etc/modprobe.d/iwlwifi.confAdd a new line:
options iwlwifi 11n_disable=1Save and reboot.
Solution 2:
When solution 1 failed, I tried solution 2 as shown here below;
lspci -nnk | grep -iA2 net
lsmod
iwconfig
rfkill list
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI
Express Fast Ethernet controller [10ec:8136] (rev 05)
Subsystem: Acer Incorporated [ALI] Device [1025:061f]
Kernel driver in use: r8169
02:00.0 Network controller [0280]: Qualcomm Atheros AR9485 Wireless Network Adapter [168c:0032] (rev 01)
Subsystem: Foxconn International, Inc. Device [105b:e047]
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5209 PCI Express Card Reader [10ec:5209] (rev 01)
lsmod
Module Size Used by
nls_iso8859_1 12713 1
parport_pc 32701 0
ppdev 17671 0
bnep 19564 2
rfcomm 69070 0
bluetooth 371874 10 bnep,rfcomm
vesafb 13828 1
lp 17759 0
parport 42299 3 lp,ppdev,parport_pc
hid_generic 12548 0
usbhid 53014 0
hid 101512 2 hid_generic,usbhid
usb_storage 62062 1
rtsx_pci_sdmmc 23527 0
ahci 25819 2
libahci 31898 1 ahci
rtsx_pci 45546 1 rtsx_pci_sdmmc
r8169 67341 0
mii 13934 1 r8169
iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
rfkill list
The last command did not give an output so I could not follow the instructions that were to come as shown below;
Deactivate the hardware encryption of the driver:
Code:
echo "options ath9k nohwcrypt=1" | sudo tee /etc/modprobe.d/ath9k.conf
sudo modprobe -rfv ath9k
sudo modprobe -v ath9k
Any help either along these steps or any other solution will be appreciated.
