164
I like Unity very much. Recently, I installed Compiz manager and Nautilus Elementary also then tried to Play. During some of my playing around, Unity's clock applet has vanished.
I want to make it show the time again. How can I do this?
Oli
  • 299,380
Dev
  • 1,641
7 Answers7
293
Having date and time gone on Ubuntu 13.10 beta, after next reboot, this command solves the problem:
killall unity-panel-service
Lucio
  • 19,191
  • 32
  • 112
  • 191
Maxime
  • 3,254
  • 13
Reinstall indicator-datetime. It should be installed by default, but just in case you have removed it unknowingly, it is best to run the install command again.
sudo apt-get install indicator-datetime
Next, we are going to reconfigure the date time:
sudo dpkg-reconfigure --frontend noninteractive tzdata
Lastly, restart unity.
sudo killall unity-panel-service
Patryk
  • 9,416
36
  1. Click the Ubuntu logo in the top-left.
  2. Search for and open "Time and Date".
  3. Open the Clock tab.
  4. Make sure the box "Show a clock in menu bar" is ticked.
Also make sure the package indicator-datetime is installed.
19
Double check that indicator-datetime Install indicator-datetime is installed. Go to terminal and type
Now log out and then back in.
user28525
  • 199
On my computer, Unity shows word "Time" instead of the real time.
On Ubuntu 11 (and above?) /etc/timezone can't be empty (and it was). This wasn't an issue on previous versions.
To regenerate the TimeZone file just do:
It works for me.
smhg
  • 113
If that doesn't work you can try restoring your defaults.
From your unity session, try re-launching unity like this:
unity --reset
If you not found Date-Time on panel then try to find out on whether its hide or not. If not then try to find out its installed or not.
If you find that Date-Time not install then you just install it. 1. apt-get install indicator-datetime 2. killall unity-panel-service
You not need to Logoff or reset Unnity. Just check on your Desktop's Right Corner.
Neo
  • 49
