33
Fresh install of Ubuntu GNOME 14.04 with 3 displays (fglrx driver). I can correct the screens order in System Settings / Display but it is not saved when I close the session and reopen it.
Screens order in GDM is also wrong. Copy/pasting the .config/monitors.xml file into /var/lib/gdm/.config/ doesn't change anything.
Does anybody have an idea ?
chewiiie
  • 341
I have the same issue
seems like gnome-settings-daemon is not loading monitors.xml at startup
my work around is to run this command
pkill -9 -f gnome-settings-daemon
as a "Startup Application"
i have documented this in my ubuntu 14.04 update and problems post
not sure if there is a better solution
otm
  • 622
Looks like a bug to me. If you'd like to see it corrected I would suggest that you mark on the official report that this bug affects you.
k0pernikus
  • 6,336
user275428
  • 41
There is one more workaround: Link to article
It basically says that ~/.config/monitors.xml is not applied on startup. So the author created a script which basically does something like this:
xrandr --output LVDS --pos 1920x0 --output CRT1 --pos 0x0
...and adds this to Gnome startup programs.
Zlatko
  • 211
