I have downloaded the link provided in home page of Ubuntu i.e., 12.04 for desktop ubuntu. I got downloaded a file which of size 733 MB in ISO format and then I extract files from the ISO image and then I click on the Wubi and it re-directed me into a link and took me an 30 mins or so.
After completing the download, installation came to halt throwing some log error. It happened 2 times for me. Is there anything problem with my process with my installation process or is there any other process for installing? Currently I'm using Windows 8 and I'm trying to install Ubuntu from Windows 8. Help me with this problem. Thanks in advance.
Danatela
  • 13,384
Chani
(Everything I have read about Wubi indicates you should not use it!) I recently installed Ubuntu 12.04 LTS, downloaded the file and burned to a DVD. You can run Ubuntu from the DVD so you can try it out without installing it. If you choose to install it is pretty easy, try dual-boot (mine is with XP). There is a partition manager in the install program, I set my partitions about half & half between Ubuntu and XP. After installation a new bootup screen will appear which will allow you to boot either operating system. My XP still works fine, no problems.
My total installation time was around 2 hours including downloading Ubuntu and burning the DVD.
After that I spent HOURS checking out Ubuntu! There are a lot of programs included. It recognized my network immediately and I was online doing email in minutes. Also downloaded pics from my phone right away.
Good luck, you can do it!
B. Fife
  • 49
The general instruction you should follow: How do I install Ubuntu?
Instruction for Windows 8 64-bit UEFI: Installing Ubuntu Alongside a Pre-Installed Windows with UEFI
Also, there is a special tag for dual-boot. Just read those instructions.
Do not use Wubi. It's not designed for Windows 8 and it's support discontinued after 13.04 Release
Danatela
  • 13,384
