Yeah the lookup is pretty complicated. Here are the freedesktop icon specifications on directory layouts:
Icons and themes are looked for in a set of directories. By default,
apps should look in $HOME/.icons (for backwards compatibility), in
$XDG_DATA_DIRS/icons and in /usr/share/pixmaps (in that order).
Applications may further add their own icon directories to this list,
and users may extend or change the list (in application/desktop
specific ways).In each of these directories themes are stored as
subdirectories. A theme can be spread across several base directories
by having subdirectories of the same name. This way users can extend
and override system themes.
In order to have a place for third party applications to install their
icons there should always exist a theme called "hicolor" 1. The data
for the hicolor theme is available for download at:
http://www.freedesktop.org/software/icon-theme/. Implementations are
required to look in the "hicolor" theme if an icon was not found in
the current theme.
Each theme is stored as subdirectories of the base directories. The
internal name of the theme is the name of the subdirectory, although
the user-visible name as specified by the theme may be different.
Hence, theme names are case sensitive, and are limited to ASCII
characters. Theme names may also not contain comma or space.
In at least one of the theme directories there must be a file called
index.theme that describes the theme. The first index.theme found
while searching the base directories in order is used. This file
describes the general attributes of the theme.
In the theme directory are also a set of subdirectories containing
image files. Each directory contains icons designed for a certain
nominal icon size, as described by the index.theme file. The
subdirectories are allowed to be several levels deep, e.g. the
subdirectory "48x48/apps" in the theme "hicolor" would end up at
$basedir/hicolor/48x48/apps.
The image files must be one of the types: PNG, XPM, or SVG, and the
extension must be ".png", ".xpm", or ".svg" (lower case). The support
for SVG files is optional. Implementations that do not support SVGs
should just ignore any ".svg" files. In addition to this there may be
an additional file with extra icon-data for each file. It should have
the same basename as the image file, with the extension ".icon". e.g.
if the icon file is called "mime_source_c.png" the corresponding file
would be named "mime_source_c.icon".
The full specifications are much more exhausti{ve,ng} than this but the crux of it is: there are set directories you can just stuff icons into and the desktop will find them. Which of those best applies to you depends on your problem and your patience :)
