256
I used to work on the Mac terminal before and I used:
open file2open.pdf
and the PDF file would be opened on preview or whatever my default viewer was. When I use it in the terminal in Ubuntu I get this error message:
Couldn't get a file descriptor referring to the console
yayu
  • 3,421
13 Answers13
290
Most desktop environments on modern systems (generic)
open file2open.xxx
OR
xdg-open file2open.xxx
GNOME
  • until Xenial (16.04):
    gvfs-open file2open.xxx
  • starting with Artful (17.10):
    gio open file2open.xxx
(xxx = some file extension). With this command the default app for xxx will be invoked (for example evince if you want to open PDF).
Application-specific
  • Using Evince, GNOME’s default document viewer:
    evince file2open.pdf
  • Using Okular, KDE’s default document viwer:
    okular file2open.pdf
desgua
  • 33,215
106
You can also use:
xdg-open foo.pdf
xdg-open works in Gnome, KDE, xfce, LXDE and perhaps on other desktops.
You can put an alias in your ~/.bash_aliases:
alias open=xdg-open
elmicha
  • 9,960
22
For all those lost Mac users in Ubuntu-land ..
Edit your .bashrc file, and add:
alias open='gnome-open'
Then you can just use:
open file2open.pdf
david6
  • 14,528
  • 38
  • 46
15
if the pdf is simple...
pdftotext -layout file2open.pdf - | more
We can use this in text mode, ssh, etc.
11
If you want to view PDF within Terminal (Command Line Interface), try to use zathura.
Install Zathura sudo apt-get install zathura -y.
To view a PDF file just run => zathura /path/to/xxx.pdf
BTW: zathura requires X11 anyway, it doesn't work on Servers with no X installed.
Tim
  • 33,500
Terry Wang
  • 10,185
11
if you have Document Viewer installed type the following command:
evince Name_of_pdf_file
if it is not already installed you can install it firstly using the following command:
sudo apt-get install evince
In Ubuntu 17.04 you case use this:
gio open <file.pdf>
jairojj
  • 31
You can also use
ooffice filename.pdf
to open your file in open office.
A.B.
  • 92,125
The Z shell (zsh) has suffix based alias (-s), these allow you to set up a file association between a file extension like .jpg and a suitable application like xreader:
alias -s pdf='xreader'
With an alias like that you just need to type the file name and hit ↵ Return, e.g.:
file.pdf
dessert
  • 40,956
zzapper
  • 151
I personally use a shell script:
$ cat pdf
#! /bin/bash
gnome-open ${1:-*.pdf}
When you call pdf it will open all pdfs in the current directory, specify which pdf by supplying an argument. I have many directories containing but one pdf file (e.g. so many LaTeX directories) so only having to write pdf saves me quite some time and keystrokes.
user93692
  • 142
You can define the following function in your ~/.bashrc
open () {
     read -p "Enter File Name: " ; xdg-open "$REPLY"
muru
  • 207,228
Too open with Libre office use:
loffice <file.pdf>
or
soffice <file.pdf>
or
Goplay -
gooffice <file.pdf>
Ani Menon
  • 131
You can also type:
firefox file_name.pdf
This will open your pdf in firefox browser.
muru
  • 207,228
