I'm using this command: gnome-open file_name.xxx(xxx file extension) command but it's not working. I'm using Ubuntu 14.04.
Asked
Active
Viewed 2.7k times
You could either try xdg-open (xdg-open - opens a file or URL in the user's preferred application):
xdg-open /path/to/file.pdf
Or you directly launch Evince, the default Ubuntu document viewer, and open the file with it:
evince /path/to/file.pdf
Note that you must always quote path names with special characters like spaces or colons - or escape each of those characters using a backslash:
xdg-open '/path/with:some/special characters/strange filename.pdf'
xdg-open "/path/with:some/special characters/strange filename.pdf"
xdg-open /path/with\:some/special\ characters/strange\ filename.pdf'
evince '/path/with:some/special characters/strange filename.pdf'
evince "/path/with:some/special characters/strange filename.pdf"
evince /path/with\:some/special\ characters/strange\ filename.pdf'
You may chose the variant you prefer.
Byte Commander
- 110,243
