-1
I want to open my pdf files using Terminal but I donot want to use this "xdg-open" command every time. What is the solution. Thank You
If you want to write as less as possible when opening a pdf file, you should define an alias. In a file called ~/.bashrc you can define aliases like this:
alias pdf="evince "
Refresh the environment with
. ~/.bashrc
and then use the alias:
pdf file.pdf
