I know this has been asked multiple times before, but most of these threads don't have an answer. I tried user62664's solution here and ran sudo update-grub successfully, but nothing changed. This happens whether I type sudo reboot or sudo shutdown -h now. Here is what it looks like when it hangs. There are no error messages, everything shows up with '[OK]', and then:
* Deconfiguring network interfaces...          [OK]
* Deactivating swap...                         [OK]
* Unmounting local filesystems...              [OK]
* Will now restart
[ 1306.738916] mei_me 0000:00:16.0: stop
[ 1306.739745] reboot: Restarting system
_
This seems like a very common problem, yet there are very few answers and they don't seem to help in my case. Does this mean there is no one solution? In which case, where should I check to check to find out the root cause?
biohazard
  • 143
From the man shutdown:
OPTIONS
       -r     Requests  that  the system be rebooted after it has been brought
              down.
       -h     Requests that the system be either halted or powered  off  after
              it has been brought down, with the choice as to which left up to
              the system.
       -H     Requests that the system be halted after  it  has  been  brought
              down.
       -P     Requests  that  the  system  be  powered  off  after it has been
              brought down.
As you can see, options -H and -P will poweroff your system. And sudo reboot will only reboot your computer, because it is so designed.
For rebooting your system wishout hanging up I can recommend sudo shutdown -r and sudo init 6. 【⬅This did not work out for me @biohazard】
biohazard
  • 143
Danatela
  • 13,384
Passing a reboot= parameter to the kernel can solve this issue, no matter which shutdown command is used.
See http://linux.koolsolutions.com/2009/08/04/howto-fix-linux-hangfreeze-during-reboots-and-restarts/ for more details.
In my case, reboot=pci fixed the problem for a Dell Optiplex 790.
When you make shutdown press super+F1 you will see the problem if it is like the following :
Buffer I/O error on device fd0 logical Block 0
you must then go to BIOS and stop the floppy drive !
if it is something else just say at add comment
adam
  • 29
