For a completely unrelated problem, I ran update-grub following the instructions in user62644's answer to this post. Ever since, the GUI has been loading by default upon boot, and I have to type Ctrl+Alt+F1 to access the bash shell. I would like the bash shell to load by default upon startup, and just type startx whenever I need the GUI. I'm running Ubuntu 12.04 LTS.
biohazard
  • 143
Edit /etc/default/grub and change this:
GRUB_CMDLINE_LINUX_DEFAULT="acpi=noirq quiet splash"
to this:
GRUB_CMDLINE_LINUX_DEFAULT="acpi=noirq quiet text"
This assumes you actually need the acpi=noirq that was in the linked answer. I can't tell you that, it depends on your hardware. Anyway, once you've done this, refresh grub:
sudo update-grub
And you should now load directly to text.
terdon
  • 104,119
Use
sudo update-rc.d lightdm remove
And you will see desired bash logon shell on startup
To restore:
sudo update-rc.d lightdm defaults
Danatela
  • 13,384
