26
My computer is overheating because I got too many desktop environments installed like: MATE, Cinnamon and XFCE. I uninstalled them, but XFCE failed to uninstall. I get this error.
 sudo apt-get purge xfce4
    Reading package lists... Error!
    E: Problem syncing the file - sync (5: Input/output error)
    E: The package lists or status file could not be parsed or opened.
MathCubes
  • 5,732
Liso
  • 15,677
7 Answers7
31
Try this
sudo apt-get purge xfconf xfce4-utils xfwm4 xfce4-session xfdesktop4 exo-utils xfce4-panel xfce4-terminal  thunar
followed by
sudo apt autoremove
Zanna
  • 72,312
Meow
  • 1,427
11
Try these
sudo apt-get -f install
sudo apt-get clean
sudo apt-get autoclean
sudo apt-get update
Now
Maythux
  • 87,123
In my case (Mint with cinnamon and XFCE) I did:
sudo apt-get clean
sudo apt-get update
THEN:
sudo apt-get purge xfce4  # failed
THEN:
sudo apt-get autoremove
sudo apt-get clean
sudo apt-get update
Zanna
  • 72,312
From this link
You can run the following to remove xfce from your computer, completely:
dpkg -l | grep .xfce. | xargs sudo apt-get purge --auto-remove --yes
Try this:
sudo apt purge ^xfce4*
Then:
sudo apt autoremove
Onluck
  • 46
First, check what is going to be removed
sudo dpkg -l | grep .xfce.
If you are ok with it, run this command
sudo apt autoremove --purge xfce*
Command explanation
# dpkg -l       lists all installed packages
# grep .xfce.   filters, so that only packages with keyword xfce within their names, listed
# purge         removes mentioned package
# autoremove    tries to remove dependency packages
Pran
  • 159
-3
try : sudo apt-get remove xfce4-* this helps in removing all linked packages, after you have executed sudo apt-get purge xfce4, of course.
