234
Can I directly download audio from a YouTube video instead of first downloading audio+video and then extracting the audio?
Braiam
  • 69,112
DK Bose
  • 44,553
Here is a recent article in webupd8.org that explains how to use youtube-dl to directly download audio instead of first downloading video+audio and then extracting audio using -x. Unfortunately, the search facility that Maythux asked for here isn't offered. But it is still worth a look:
Video Downloader youtube-dl Gets Support For Separate Audio And Video YouTube DASH Streams
Basically, download the latest version of youtube-dl from source or from the ppa offered in the link above but not from the Software Center.
Then, if you already have the video link ...
Run, as example:
youtube-dl -F 'http://www.youtube.com/watch?v=HRIF4_WzU1w'
This will list the various download formats available for this url (audio and video).
$ youtube-dl -F 'http://www.youtube.com/watch?v=HRIF4_WzU1w'
[youtube] Setting language
[youtube] HRIF4_WzU1w: Downloading webpage
[youtube] HRIF4_WzU1w: Downloading video info webpage
[youtube] HRIF4_WzU1w: Extracting video information
[info] Available formats for HRIF4_WzU1w:
format code extension resolution  note
171         webm      audio only  DASH webm audio , audio@ 48k (worst)
140         m4a       audio only  DASH audio , audio@128k
160         mp4       192p        DASH video
133         mp4       240p        DASH video
134         mp4       360p        DASH video
135         mp4       480p        DASH video
17          3gp       176x144
36          3gp       320x240
5           flv       400x240
43          webm      640x360
18          mp4       640x360     (best)
Now, choose desired audio format. I went for 140
Run:
youtube-dl -f 140 'http://www.youtube.com/watch?v=HRIF4_WzU1w'
$ youtube-dl -f 140 'http://www.youtube.com/watch?v=HRIF4_WzU1w' [youtube] Setting language [youtube] HRIF4_WzU1w: Downloading webpage [youtube] HRIF4_WzU1w: Downloading video info webpage [youtube] HRIF4_WzU1w: Extracting video information [download] Destination: Martin Luther King - I Have a Dream on August 28, 1963 [Sous-titres & Subtitles] [FULL SPEECH]-HRIF4_WzU1w.m4a [download] 100% of 15.19MiB in 00:04
That's it.
mchid
  • 44,904
  • 102
  • 162
DK Bose
  • 44,553
98
From @xiota's comment, to download the best audio in m4a format:
$ youtube-dl -f 'bestaudio[ext=m4a]' 'http://youtu.be/hTvJoYnpeRQ'
I've missed it on the first reading, so I've decided to post the comment as an answer to make it more visible.
jfs
  • 4,078
33
This alias let me easily download any audio with better filenames:
$ alias | grep audio
alias yt-dl-audio='yt-dlp --ignore-errors --output "%(title)s.%(ext)s" --extract-audio --audio-format mp3'
I switched from youtube-dl to yt-dlp. Works faster and includes things like --split-chapters. Most things are equivalent.
About audio quality: From the documentation: "By default yt-dlp/youtube-dl tries to download the best available quality, i.e., if you want the best quality you don't need to pass any special options, yt-dlp will guess it for you by default.". So there's no need for --audio-quality 0 or -f bestaudio.
About Updates: Download last version of yt-dlp. Avoid repo, PPA version or pip/pipx so you can upgrade with yt-dlp -U (necessary quite often).
To install it right away for all UNIX users (Linux, OS X, etc.), type:
sudo curl -L https://github.com/yt-dlp/yt-dlp/releases/latest/download/yt-dlp -o /usr/local/bin/yt-dlp
sudo chmod a+rx /usr/local/bin/yt-dlp  # Make executable
Albums (or compilations, mashups, etc.): You can split the file into chunks/tracks with mp3split. To generate the playlist timestamps (like the ones found on YouTube comments) and track count:
ffmpeg -i input.mp3 -af silencedetect=n=-40dB:d=2.7 -f null - |& awk '/silence_end/ {print $4,$5}' | awk '{S=$2;printf "%d:%02d:%02d\n",S/(60*60),S%(60*60)/60,S%60}' | tee >(wc -l)  # Play with tolerance (n/noise threshold level) and duration on silencedetect. More: `ffmpeg -h filter=silencedetect`.
Please leave a comment if you found a better approach, maybe something using MusicBrainz.
Common problems
Alternatives and other notes
  • ytmdl: A simple script to get songs from YouTube in mp3 format with all tags from iTunes.
  • To download in batch from a plain text, here.
  • MP3 Tagging: I’m still trying to find a reliable CLI tool to fix and tag all the generated mp3:
Pablo Bianchi
  • 17,371
