If you prefer to leave /proc/sys/kernel/yama/ptrace_scope set to its default value of 1, then as a workaround you could consider using gdb to run the program you want to debug. You can then bring up the debugger simply by pressing ^C. For example, to debug to the (boring) program sleep 60, do the following:
$ gdb -q sleep -ex 'run 60'
Here is a complete example.
Reading symbols from sleep...(no debugging symbols found)...done.
Starting program: /bin/sleep 60
^C
Program received signal SIGINT, Interrupt.
0x00007ffff7ad5d60 in __nanosleep_nocancel () at ../sysdeps/unix/syscall-template.S:81
81 ../sysdeps/unix/syscall-template.S: No such file or directory.
(gdb) backtrace
#0 0x00007ffff7ad5d60 in __nanosleep_nocancel () at ../sysdeps/unix/syscall-template.S:81
#1 0x0000000000403cd7 in ?? ()
#2 0x0000000000403b88 in ?? ()
#3 0x00000000004016c9 in ?? ()
#4 0x00007ffff7a35ec5 in __libc_start_main (main=0x401540, argc=2, argv=0x7fffffffea08, init=<optimized out>,
fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffe9f8) at libc-start.c:287
#5 0x00000000004017d5 in ?? ()
(gdb) continue
Continuing.
[Inferior 1 (process 3531) exited normally]
(gdb) quit
Since /bin/sleep was (unsurprisingly) compiled without debugging information, the above backtrace contains minimal information.
