I'm attempting to install .Net 4.5 with winetricks as described in https://appdb.winehq.org/objectManager.php?sClass=version&iId=25478&iTestingId=90239
I'm on Ubuntu 14.04 64 bit. I'm using Ubuntu Gnome as my desktop environment. I've searched extensively for a solution to this problem, but I can not find one.
I'm currently using wine-1.8, but I have the same issue with wine 1.7. Before I posted this I reset all my wine libraries.
# Remove wine related things
sudo apt-get remove wine-mono4.5.4
sudo apt-get remove playonlinux wine*
sudo apt-get remove winbind
# Do a fresh install of wine
sudo add-apt-repository ppa:ubuntu-wine/ppa -y
sudo apt-get update
#sudo apt-get install wine1.7
sudo apt-get install wine1.8
sudo apt-get install playonlinux
sudo apt-get install winbind
# Grab the latest winetricks
mkdir -p ~/tmp
cd ~/tmp
rm winetricks
wget https://raw.githubusercontent.com/Winetricks/winetricks/master/src/winetricks
chmod +x ~/tmp/winetricks
I'm running the following procedure:
# Start fresh with a new wine directory
rm -rf $HOME/.wine32-dotnet45
# Make new WINEPREFIX
export WINEPREFIX="$HOME/.wine32-dotnet45"
export WINEARCH=win32
WINEARCH=win32
# Initial configuration of new wine prefix
wineboot -u
# Execute command to install dotnet45 as shown in documentation
~/tmp/winetricks -q dotnet45 corefonts
I've tried various versions of the above procedure (installing winbind, not installing winbind, wine1.7, wine1.8, with / without corefonts etc...). However, every time I run the last command I end up getting this error:
Note: command 'wine dotnetfx3.exe /q /c:install.exe /q' returned status 67. Aborting.
I've googled for this error and tried many things to fix it, but I've come up with nothing. Hopefully someone here can help.
The output of the command is:
(venv)joncrall@Ooo:~/tmp$ ~/tmp/winetricks -q dotnet45 corefonts
Using winetricks 20160425 - sha1sum: ca54e3e664a0bffb0fc08e834900fdb58d067a9f with wine-1.8.0
Executing w_do_call dotnet45
Executing load_dotnet45
Executing w_do_call remove_mono
Executing load_remove_mono
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
DELETE - HKLM\Software\Microsoft\NET Framework Setup\NDP\v4 (null) 0 0 1
Error: The system was unable to find the specified registry key or value
Executing rm -f /home/joncrall/.wine32-dotnet45/dosdevices/c:/windows/system32/mscoree.dll
Executing w_do_call dotnet35
Executing load_dotnet35
dotnet35 does not yet fully work or install on wine. Caveat emptor.
Mono does not appear to be installed.
Executing w_do_call dotnet30sp1
Executing load_dotnet30sp1
Executing w_do_call dotnet20
Executing load_dotnet20
Executing w_do_call fontfix
Executing load_fontfix
Setting Windows version to win2k
Executing winetricks_early_wine regedit /S C:\windows\Temp\_dotnet20\set-winver.reg
Working around wine bug 34803
DELETE - HKLM\Software\Microsoft\.NETFramework\v2.0.50727\SBSDisabled (null) 0 0 1
Executing wine dotnetfx.exe /q /c:install.exe /q
fixme:advapi:DecryptFileA ("C:\\users\\joncrall\\Temp\\IXP000.TMP\\", 00000000): stub
fixme:advapi:LsaOpenPolicy ((null),0x33f2f8,0x00000001,0x33f2e4) stub
fixme:advapi:LsaClose (0xcafe) stub
err:mscoree:LoadLibraryShim error reading registry key for installroot
fixme:msi:ITERATE_DuplicateFiles We should track these duplicate files as well
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\cscomp.dll", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\mscorsn.dll", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\mscorwks.dll", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\system32\\mscoree.dll", "C:\\windows\\system32\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\mscorjit.dll", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\mscorpe.dll", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\vbc.exe", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
fixme:imagehlp:BindImageEx (0, "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\diasymreader.dll", "C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\", (null), (nil)): stub
err:ole:CoGetClassObject class {4e14fba2-2e22-11d1-9964-00c04fbbb345} not registered
err:ole:create_server class {4e14fba2-2e22-11d1-9964-00c04fbbb345} not registered
fixme:ole:CoGetClassObject CLSCTX_REMOTE_SERVER not supported
err:ole:CoGetClassObject no class object {4e14fba2-2e22-11d1-9964-00c04fbbb345} could be created for context 0x15
fixme:mofcomp:wmain stub
err:ole:CoGetClassObject class {a9e69610-b80d-11d0-b9b9-00a0c922e750} not registered
err:ole:create_server class {a9e69610-b80d-11d0-b9b9-00a0c922e750} not registered
err:ole:CoGetClassObject no class object {a9e69610-b80d-11d0-b9b9-00a0c922e750} could be created for context 0x17
fixme:advapi:RegisterEventSourceW ((null),L"ASP.NET 2.0.50727.0"): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0004,0x0001,0x400003f9,(nil),0x0002,0x00000000,0x33ecdc,(nil)): stub
fixme:advapi:DeregisterEventSource (0xcafe4242) stub
fixme:loadperf:UnloadPerfCounterTextStringsW (L"u \"ASP.NET_2.0.50727\"", 1): stub
fixme:advapi:LsaOpenPolicy ((null),0x33e880,0x000f0fff,0x33e8c0) stub
fixme:advapi:LsaStorePrivateData (0xcafe,0x33e8b4,(nil)) stub
fixme:advapi:GetExplicitEntriesFromAclW 0x520190 0x33e7e8 0x33e7d4
fixme:loadperf:LoadPerfCounterTextStringsW (L"l \"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\aspnet_state_perf.ini\"", 1): stub
fixme:service:svcctl_ChangeServiceConfig2W SERVICE_CONFIG_FAILURE_ACTIONS not implemented: period 86400 msg (null) cmd (null)
fixme:service:svcctl_ChangeServiceConfigW Setting password not supported
fixme:loadperf:LoadPerfCounterTextStringsW (L"l \"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\aspnet_perf.ini\"", 1): stub
fixme:loadperf:UnloadPerfCounterTextStringsW (L"u ASP.NET", 1): stub
fixme:loadperf:LoadPerfCounterTextStringsW (L"l \"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\aspnet_perf2.ini\"", 1): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0002,0x0001,0x800003fc,(nil),0x0000,0x00000000,0x33ece4,(nil)): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0004,0x0001,0x400003fb,(nil),0x0002,0x00000000,0x33ecdc,(nil)): stub
fixme:msvcrt:__clean_type_info_names_internal (0x6a2e3f5c) stub
fixme:thread:SetThreadStackGuarantee (0x33fc68): stub
fixme:shell:URL_ParseUrl failed to parse L"System.EnterpriseServices"
fixme:shell:URL_ParseUrl failed to parse L"System"
err:ole:CoGetClassObject class {ecabb0c8-7f19-11d2-978e-0000f8757e2a} not registered
err:ole:CoGetClassObject no class object {ecabb0c8-7f19-11d2-978e-0000f8757e2a} could be created for context 0x1
err:ole:CoGetClassObject class {6eb22881-8a19-11d0-81b6-00a0c9231c29} not registered
err:ole:create_server class {6eb22881-8a19-11d0-81b6-00a0c9231c29} not registered
err:ole:CoGetClassObject no class object {6eb22881-8a19-11d0-81b6-00a0c9231c29} could be created for context 0x15
fixme:msvcrt:__clean_type_info_names_internal (0x60345090) stub
fixme:process:FlushProcessWriteBuffers : stub
fixme:msvcrt:__clean_type_info_names_internal (0x1001da84) stub
fixme:msvcrt:__clean_type_info_names_internal (0x7a38d5c8) stub
fixme:thread:SetThreadStackGuarantee (0x33f000): stub
err:ole:CoInitializeEx Attempt to change threading model of this apartment from apartment threaded to multi-threaded
err:ole:CoGetContextToken apartment not initialised
err:ole:CoReleaseMarshalData IMarshal::ReleaseMarshalData failed with error 0x8001011d
fixme:msvcrt:__clean_type_info_names_internal (0x790af2cc) stub
fixme:thread:SetThreadStackGuarantee (0x33ef44): stub
fixme:msvcrt:__clean_type_info_names_internal (0x64083a50) stub
fixme:shell:URL_ParseUrl failed to parse L"System.Drawing"
fixme:shell:URL_ParseUrl failed to parse L"System.Windows.Forms"
fixme:shell:URL_ParseUrl failed to parse L"System.Configuration"
fixme:shell:URL_ParseUrl failed to parse L"System.Xml"
fixme:msvcrt:__clean_type_info_names_internal (0x64208a74) stub
fixme:msvcrt:__clean_type_info_names_internal (0x63fa7368) stub
fixme:shell:URL_ParseUrl failed to parse L"System.Drawing.Design"
fixme:shell:URL_ParseUrl failed to parse L"Accessibility"
fixme:shell:URL_ParseUrl failed to parse L"System.Security"
fixme:shell:URL_ParseUrl failed to parse L"System.Runtime.Serialization.Formatters.Soap"
fixme:shell:URL_ParseUrl failed to parse L"System.Deployment"
fixme:loadperf:LoadPerfCounterTextStringsW (L"C:\\windows\\system32\\lodctr.exe C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\_Networkingperfcounters.ini", 0): stub
fixme:loadperf:LoadPerfCounterTextStringsW (L"C:\\windows\\system32\\lodctr.exe C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\_DataOracleClientPerfCounters_shared12_neutral.ini", 0): stub
fixme:loadperf:LoadPerfCounterTextStringsW (L"C:\\windows\\system32\\lodctr.exe C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\_dataperfcounters_shared12_neutral.ini", 0): stub
fixme:loadperf:LoadPerfCounterTextStringsW (L"C:\\windows\\system32\\lodctr.exe C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\_DataPerfCounters.ini", 0): stub
fixme:loadperf:LoadPerfCounterTextStringsW (L"C:\\windows\\system32\\lodctr.exe C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\corperfmonsymbols.ini", 0): stub
Setting Windows version to winxp
Installing .net 3.0 runtime takes 3 minutes on a very fast machine, and the Finished dialog may hide in the taskbar.
Executing winetricks_early_wine regedit /S C:\windows\Temp\_dotnet30\set-winver.reg
Executing wine dotnetfx3.exe /q /c:install.exe /q
fixme:clusapi:GetNodeClusterState ((null),0x33ebf4) stub!
fixme:advapi:DecryptFileA ("c:\\43d72e875be0f81c93a29f98\\", 00000000): stub
fixme:ole:CoInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:advapi:LsaOpenPolicy ((null),0x33ef68,0x00000001,0x33ef60) stub
fixme:advapi:LsaOpenPolicy ((null),0x33e5f8,0x00000001,0x33e5e4) stub
fixme:ngen:wmain stub: L"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\ngen.exe" L"queue" L"pause"
fixme:mountmgr:harddisk_ioctl Unsupported ioctl 2d0c00 (device=2d access=0 func=300 method=0)
fixme:cdrom:CDROM_GetMediaType : faking success
fixme:advapi:LsaOpenPolicy ((null),0x33dd68,0x00000001,0x33dd54) stub
fixme:msi:MsiGetFeatureValidStatesW 1 L"WAP_1.0_Core" 0x33aae4 stub returning 8
fixme:msi:MsiGetFeatureValidStatesW 1 L"Servicing_Key" 0x33aae4 stub returning 8
fixme:advapi:DecryptFileA ("c:\\d11680f21c83bfdf97b0\\", 00000000): stub
fixme:setupapi:pSetupGetGlobalFlags stub
fixme:wintrust:WinVerifyTrust unimplemented for 4
err:ole:CoGetClassObject class {acadf079-cbcd-4032-83f2-fa47c4db096f} not registered
err:ole:CoGetClassObject no class object {acadf079-cbcd-4032-83f2-fa47c4db096f} could be created for context 0x1
fixme:msg:pack_message msg 14 (WM_ERASEBKGND) not supported yet
fixme:sfc:SFC_3 0
fixme:wintrust:CryptCATGetCatAttrInfo 0x1bdec8, L"SPAttr"
fixme:wintrust:CryptCATGetCatAttrInfo 0x1bdec8, L"SPLevel"
fixme:advapi:RegisterTraceGuidsW (0x10182d6, 0x1099138, {aefe45f4-8548-42b4-b1c8-25673b07ad8b}, 1, 0x33fd10, (null), (null), 0x1099140): stub
fixme:advapi:RegisterTraceGuidsW register trace class {aefe45f4-8548-42b4-b1c8-25673b07ad8b}
fixme:heap:RtlSetHeapInformation (nil) 1 (nil) 0 stub
fixme:advapi:RegisterEventSourceW ((null),L"Microsoft-Windows-SpoolerFilterPipelineSVC"): stub
fixme:psdrv:PSDRV_UpdateDevCaps Can't find page
fixme:winspool:AddPrintProcessorW ((null),L"Windows NT x86",L"filterpipelineprintproc.dll",L"MS_XPS"): stub
fixme:advapi:UnregisterTraceGuids deadbeef: stub
fixme:advapi:RegisterEventSourceA ((null),"NtServicePack"): stub
fixme:advapi:RegisterEventSourceW (L"",L"NtServicePack"): stub
fixme:advapi:ReportEventA (0xcafe4242,0x0004,0x0000,0x400e1119,0x464d20,0x0002,0x00000000,0x33bc88,(nil)): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0004,0x0000,0x400e1119,0x464d20,0x0002,0x00000000,0x147880,(nil)): stub
fixme:advapi:LsaOpenPolicy ((null),0x33d098,0x00000001,0x33d084) stub
fixme:shell:URL_ParseUrl failed to parse L"System.ServiceModel.Install"
fixme:shell:URL_ParseUrl failed to parse L"Microsoft.Web.Administration"
fixme:shell:URL_ParseUrl failed to parse L"System.ServiceProcess"
fixme:shell:URL_ParseUrl failed to parse L"System.Web"
fixme:shell:URL_ParseUrl failed to parse L"System.ServiceModel.Install.XmlSerializers"
fixme:advapi:RegisterEventSourceW (L".",L"System.ServiceModel.Install 3.0.0.0"): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0001,0x0000,0x00000000,(nil),0x0001,0x00000000,0x93f8d0,0x93f778): stub
err:eventlog:ReportEventW L"System.ArgumentException: Item has already been added. Key in dictionary: 'latex' Key being added: 'latex'\r\n at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)\r\n at System.Collections.Hashtable.Add(Object key, Object value)\r\n at System.Collections.Specialized."...
fixme:msvcrt:__clean_type_info_names_internal (0x5e40072c) stub
err:msi:ITERATE_Actions Execution halted, action L"DD_CA_InstallXwsRegExe_X86.3643236F_FC70_11D3_A536_0090278A1BB8" returned 1603
fixme:ngen:wmain stub: L"C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\ngen.exe" L"queue" L"continue"
I removed some of the redundant parts to get within the character limit, but anything important in there should still be visible.
The full output is in this pastebin http://pastebin.com/nwcLW2vY
Furthermore, if I rerun the command I get this error:
error: dotnet45 conflicts with dotnet20, which is already installed.
so I have to blow away my entire WINEPREFIX every time I try something new.
