Hi I would like to know if I can upgrade gedit to version 3.6.3 in Ubuntu 12.04 without the webupd8 ppa. I think the process would be similar like this: Is there any way to Install Latest Nautilus File Manager in Ubuntu 12.04 LTS. Please tell me if that works, Thanks in advanced!
EDIT
The info I posted above does not work.
EDIT
It looks like people want to know why, well the reason is because I want the latest features and speed improvements that came in GNOME 3.6 and all of GNOME's applications. + I already have some GNOME 3.6.3 software (As you can tell from the link above I've installed Nautilus 3.6.3 aka Files 3.6.3).
EDIT
Umm, so I am missing some of the dependencies that Gedit needs, do I download it from packages.ubuntu.com and then install it the same way I attempted to install Gedit 3.6.2?
Gedit 3.6.3 does not exist. You'll have to choose 3.6.2 or 3.8.3. Since 3.8 is a major version, I recommend to install the 3.6.2.
You should be able to build your package using these commands:
wget https://launchpad.net/ubuntu/raring/+source/gedit/3.6.2-0ubuntu1/+files/gedit_3.6.2.orig.tar.xz
tar -xvf gedit_3.6.2.orig.tar.xz
cd gedit-3.6.2/
./configure
make
sudo make install
You have to know that it is not recommended to upgrade your packages, because it may change a lot of packages in your system, possibly breaking it.
You also have to take a close look at the depedencies that Gedit 3.6.2 needs.
Seth
  • 59,332
MrVaykadji
  • 5,965
WHAT I DID
This is the process that I did. (This is based off of MrVaykadji answer)
  1. (In the Terminal) mkdir ~/Downloads/src
  2. cd ~/Downloads/src
  3. wget https://launchpad.net/ubuntu/raring/+source/gedit/3.6.2-0ubuntu1/+files/gedit_3.6.2.orig.tar.xz
  4. tar -xvf gedit_3.6.2.orig.tar.xz
  5. sudo apt-get build-dep gedit (If this command doesn't work you'll have to get the dep's yourself)
  6. cd gedit-3.6.2/
  7. ./configure
  8. make
  9. sudo make install
