Can I upgrade Totem to version 3.6.3 in Ubuntu 12.04 without the webupd8 ppa. I tried the process from here, but I have some problems with getting the dependencies. The Reason why I want Totem 3.6.3 is of course for the latest changes and speed improvements.
The solution by Wilf doesn't work! This is what happened when I followed the procedure:
david@david-VirtualBox:~$ wget
http://launchpadlibrarian.net/136994659/totem_3.6.3-0ubuntu6_amd64.deb
--2014-02-01 14:54:55-- http://launchpadlibrarian.net/136994659/totem_3.6.3-0ubuntu6_amd64.deb
Resolving launchpadlibrarian.net (launchpadlibrarian.net)...
91.189.89.229, 91.189.89.228 Connecting to launchpadlibrarian.net (launchpadlibrarian.net)|91.189.89.229|:80... connected. HTTP request
sent, awaiting response... 200 OK Length: 104032 (102K)
[application/x-debian-package] Saving to:
`totem_3.6.3-0ubuntu6_amd64.deb'
100%[======================================>] 104,032 --.-K/s in
0.005s
2014-02-01 14:54:56 (18.2 MB/s) - `totem_3.6.3-0ubuntu6_amd64.deb'
saved [104032/104032]
david@david-VirtualBox:~$ sudo dpkg -i totem_3.6.3-0ubuntu6_amd64.deb
[sudo] password for david: (Reading database ... 238277 files and
directories currently installed.) Preparing to replace totem 3.4.3-0ubuntu1~precise1 (using totem_3.6.3-0ubuntu6_amd64.deb) ...
Unpacking replacement totem ...
dpkg: dependency problems prevent configuration of totem:
totem depends on libcogl12 (>= 1.7.4); however: Package libcogl12 is not installed.
totem depends on libtotem0 (>= 3.6.3-0ubuntu6); however: Version of libtotem0 on system is 3.4.3-0ubuntu1~precise1.
totem depends on gstreamer1.0-clutter; however: Package gstreamer1.0-clutter is not installed.
totem depends on gstreamer1.0-plugins-base (>= 0.11.93); however: Package gstreamer1.0-plugins-base is not installed.
totem depends on gstreamer1.0-plugins-good (>= 0.11.93); however: Package gstreamer1.0-plugins-good is not installed.
totem depends on gstreamer1.0-x; however: Package gstreamer1.0-x is not installed.
totem depends on totem-common (= 3.6.3-0ubuntu6); however: Version of totem-common on system is 3.4.3-0ubuntu1~precise1.
dpkg: error processing totem (--install): dependency problems - leaving
unconfigured
Processing triggers for desktop-file-utils ...
Processing triggers for bamfdaemon ... Rebuilding
/usr/share/applications/bamf.index... Processing triggers for
gnome-menus ... Errors were encountered while processing: totem
And I get errors from the sudo apt-get build-dep totem
david@david-VirtualBox:~/Downloads$ sudo apt-get build-dep totem
Reading package lists... Done Building dependency tree Reading
state information... Done The following packages have unmet
dependencies:
librsvg2-dev : Depends: librsvg2-2 (= 2.36.1-0ubuntu1) but 2.36.3-0ubuntu1~precise1 is to be installed
libtotem-plparser-dev : Depends: libtotem-plparser17 (= 3.4.1-1) but 4.2-1~precise1 is to be installed
Depends: gir1.2-totem-plparser-1.0 (= 3.4.1-1) but 3.4.2-1~precise1 is to be installed E: Build-dependencies for totem could not be satisfied. david@david-
I seem to get errors from installing the depedencies that Wilf suggested, I did uninstall them before installing the newer version. Here is what I got in the terminal:
david@david-VirtualBox:~$ cd ~/Downloads/
david@david-VirtualBox:~/Downloads$ sudo dpkg -i totem-common_3.6.3-0ubuntu6_all.deb
Selecting previously unselected package totem-common.
(Reading database ... 269477 files and directories currently installed.)
Unpacking totem-common (from totem-common_3.6.3-0ubuntu6_all.deb) ...
Setting up totem-common (3.6.3-0ubuntu6) ...
Processing triggers for man-db ...
Processing triggers for gconf2 ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for libglib2.0-0 ...
david@david-VirtualBox:~/Downloads$ sudo dpkg -i libtotem0_3.6.3-0ubuntu6_amd64.deb
Selecting previously unselected package libtotem0.
(Reading database ... 269887 files and directories currently installed.)
Unpacking libtotem0 (from libtotem0_3.6.3-0ubuntu6_amd64.deb) ...
dpkg: dependency problems prevent configuration of libtotem0:
libtotem0 depends on libcogl12 (>= 1.7.4); however:
libtotem0 depends on libglib2.0-0 (>= 2.35.9); however:
Version of libglib2.0-0 on system is 2.34.1-0ubuntu1~12.04~ricotz0.
dpkg: error processing libtotem0 (--install):
dependency problems - leaving unconfigured
libtotem0
david@david-VirtualBox:~/Downloads$ sudo dpkg -i libcogl12_1.14.0-0ubuntu1_amd64.deb
Selecting previously unselected package libcogl12.
(Reading database ... 269896 files and directories currently installed.)
Unpacking libcogl12 (from libcogl12_1.14.0-0ubuntu1_amd64.deb) ...
dpkg: dependency problems prevent configuration of libcogl12:
libcogl12 depends on libc6 (>= 2.17); however:
Version of libc6 on system is 2.15-0ubuntu10.5.
libcogl12 depends on libegl1-mesa (>= 7.8.1) | libegl1-x11; however:
Package libegl1-mesa is not installed.
Package libegl1-x11 is not installed.
dpkg: error processing libcogl12 (--install):
libcogl12
Looks like I'm missing some dep's, and the libglib2.0-0 on my system (2.34.1) is newer than what is on the raring page (2.33.14) and it says I need 2.35.9, looks like I have to dig in Saucy's or Trusty's page for libglib2.0-0 v.2.35. Ok I checked, Saucy is using just the exact same version of libglib2.0-0 as raring as its still 2.33.14. However Trusty is using 2.39.3, and I'm using 2.34.1, so what should I use?
EDIT
Ignore what I said like they put the wrong version number in the description but when you go on the page it's actually 2.36.0 for Raring, 2.38.0 for Saucy, and 2.39.3 for Trusty. So should I just go with 2.36.0 or should I get 2.35.9? Wouldn't 2.36.0 work as well? I'm going to go with v.2.35.9 found here.
Ok, all these dependencies are leading to more dependencies, and it looks like an infinite loop, and Synaptic can't remove the broken packages anymore! I'll start with a backup of my Virtual Machine before I started upgrading Totem again then I can be assisted again.
Gdebi seems not to like Totem 3.6.3 ether because of the mozilla-totem plugin.
david@david-VirtualBox:~/Downloads$ sudo apt-get install gdebi-core
The following packages were automatically installed and are no longer required:
indicator-printers gir1.2-timezonemap-1.0 libdiscid0 unity-lens-video
linux-headers-3.2.0-56 unity-scope-video-remote gir1.2-json-1.0
librhythmbox-core5 libpcrecpp0 linux-headers-3.2.0-56-generic
language-pack-kde-en kde-l10n-engb libcmis-0.2-0 libmusicbrainz3-6
libpcre3-dev language-pack-kde-en-base gir1.2-xkl-1.0
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
gdebi-core
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 159 kB of archives.
After this operation, 1,198 kB of additional disk space will be used.
Get:1 http://ca.archive.ubuntu.com/ubuntu/ precise/universe gdebi-core all 0.8.5build1 [159 kB]
Fetched 159 kB in 1s (139 kB/s)
Selecting previously unselected package gdebi-core.
(Reading database ... 238277 files and directories currently installed.)
Unpacking gdebi-core (from .../gdebi-core_0.8.5build1_all.deb) ...
Setting up gdebi-core (0.8.5build1) ...
david@david-VirtualBox:~/Downloads$ sudo gdebi totem_3.6.3-0ubuntu6_amd64.deb
Building data structures... Done
This package is uninstallable
Breaks existing package 'totem-mozilla' dependency totem (= 3.4.3-0ubuntu1~precise1)
And when I install totem-mozilla 3.6.3:
david@david-VirtualBox:~/Downloads$ sudo gdebi totem-mozilla_3.6.3-0ubuntu6_amd64.deb
Dependency is not satisfiable: totem (= 3.6.3-0ubuntu6)
Ok so how do I install Totem 3.6 + all the dependencies needed without breaking any packages?
