36
I'm currently using this:
cpupower frequency-set --governor powersave
but it resets after each reboot.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Kyra
  • 501
For 16.04 there's one more step to add to Jayen's answer. The complete set of steps are
sudo apt-get install cpufrequtils
echo 'GOVERNOR="powersave"' | sudo tee /etc/default/cpufrequtils
sudo update-rc.d ondemand disable
The last step disables the "ondemand" daemon, which would otherwise overwrite the changes created by cpufrequtils.
See also How I can disable CPU frequency scaling and set the system to performance?
You might also consider adding, for example, MAX_SPEED="2GHz" to /etc/default/cpufrequtils if you have an overheating, say, 2.2GHz processor, to limit the maximum possible speed.
14
To set the governor permanently to powersave, firstly install cpufrequtils:
And then edit the /etc/init.d/cpufrequtils file and change GOVERNOR to "powersave" (GOVERNOR="powersave"). You can do this automatically by using the following command:
sudo sed -i 's/^GOVERNOR=.*/GOVERNOR="powersave"/' /etc/init.d/cpufrequtils
From here: Prevent Your Laptop From Overheating With Thermald And Intel P-State
LogicStuff
  • 137
Alin Andrei
  • 7,358
14
Based on Alin's answer, but will persist when cpufrequtils is upgraded:
And then create/edit the /etc/default/cpufrequtils file (which is read from /etc/init.d/cpufrequtils) and set GOVERNOR="powersave". You can do this automatically by using the following command:
And if you are on Ubuntu 16.04 or later, you need to disable the built-in service that sets the governor to ondemand:
Jayen
  • 395
