I have an AD Domain run by Samba4 and have successfully joined Ubuntu workstations to that domain and able to add users and log into the workstation with domain accounts. Now, I am needing to remove a domain account from that workstation so that only the end user who will be using that workstation has an account on that system--so that the temporary domain account used to configuration does not show up in the GDM login screen.. I know how to remove local users but I cannot find how to remove a domain account from said workstation. Looking online and google only tells me how to remove a domain account completely from the domain. I think it may be in my terminology when I run my search but I am not sure.
Thank you in advance.
Scott
muru
  • 207,228
Ubuntu 22.04.1 LTS
Simply removing the home folder did not work for me.
rm -r /home/user_to_remove
Another suggested solution was to use the following command:
sudo userdel --remove-home user_to_remove
But the command said could not find user. In case it was a misspelled I tried to list all available users with:
cut -d: -f1 /etc/passwd
From this answer: https://askubuntu.com/a/410274
The user was not in the list. The answer above specifically highlighted that it only listed local users.
TL;DR;
What finally worked was to go into:
Settings -> Users
Then click on the "user_to_remove" and then "Remove User..." button.
Heneer
  • 101
Just remove the domain useres home directory under /home. Ubuntu doesn't store any domain user files outside /home
sмurf
  • 4,750
  • 26
  • 30
