13
I've installed XFCE Desktop environment, but when I decide to switch back to Unity, while uninstalling the XFCE packages, the LightDM keep starts like XFCE, and I want to restore the Unity one. I think that is called Unity Greeter. Can someone help me?
Mudit Kapil
  • 2,081
8 Answers8
I installed xubuntu-desktop on top of normal Ubuntu 14.04. Then I also noticed that the greeter had changed. I still use the xubuntu desktop, but I changed the greeter back by adding a line
greeter-session=unity-greeter
into /etc/lightdm/lightdm.conf.d/10-xubuntu.conf.
Update: Now on a new install of Ubuntu 14.10 + xubuntu-desktop on top of that, there is no directory lightdm.conf.d under /etc/lightdm. But following advice from here I created the directory /etc/lightdm/lightdm.conf.d and a file /etc/lightdm/lightdm.conf.d/50-myconfig.conf with contents
[SeatDefaults]
and I get the unity greeter back.
I didn't test it, but I suspect that @SampoSmolander might have the best approach.
Alternatively, I had success by removing the gtk greeter -- apparently this is what XFCE uses.
sudo apt-get purge lightdm-gtk-greeter
There still remains the tricky issue of getting rid of XFCE's mouse-themed greeter wallpaper:
Note: It looks like multiple desktop environments install the lightdm-gtk-greeter package (including XFCE and MATE). Interestingly, once you remove that package, the configuration files that @SampoSmolander discusses are no longer present.
I had a similar problem. @SampoSmolander's answer might be the right way.
When using Ubuntu 14.04 you'll have to add the line
[SeatDefaults]
into /etc/lightdm/lightdm.conf.d/50-myconfig.conf
I wrote a detailed how-to, but I don't know if it works, because LightDM reconfiguration seems to have solved the problem for me.
mdhtr
  • 61
cd /usr/share/lightdm/lightdm.conf.d && sudo ln -s 50-unity-greeter.conf 99-unity-greeter.conf and reboot the system.
The problem is caused by lightdm-gtk-greeter installing file called 60-lightdm-gtk-greeter.conf which overrides the unity greeter. I guess we should be able to just do sudo update-alternatives --config lightdm-greeter and select unity-greeter but unity-greeter package is incorrectly built and it does not support update-alternatives.
The above command workarounds the problem by creating a symbolic link with higher number so it can override the incorrect greeter selection. I'm using symbolic link to be better prepared for the future in case the file 50-unity-greeter.conf is ever upgraded by system package.
To set the unity greeter as default, in Ubuntu 16.04 login screen, edit the file
/usr/share/lightdm/lightdm.conf.d/60-lightdm-gtk-greeter.conf
and change the "greeter-session" line to "greeter-session=unity-greeter"
Sunny127
  • 1,305
Try:
sudo dpkg-reconfigure lightdm
You could try enter this in the terminal, and it might fine this way I say:
 sudo apt-get autoremove lightdm
 sudo apt-get install --reinstall lightdm-gtk-greeter
if this dos not work you could try enter again:
 sudo dpkg-reconfigure -a lightdm-gtk-greeter
and it might work fine this way too.
Michael
  • 2,597
I had a similar problem, I lost the greeter on user switch. The solution was in the package light-locker. Just reinstall, (or install if it was removed)
sudo apt-get install light-locker
In my case it was uninstalled, but the key is the package.
