i'm using dual boot and i want to use windows 7 as the default operating system.So how can i change default OS of GRUB Boot loader?
Janindu
  • 95
use grub-set-default
$ sudo grub-set-default ENTRY
ENTRY is a number or a menu item title
or edit /boot/grub/grub.cfg
sudo chmod +w /boot/grub/grub.cfg
sudo vi /boot/grub/grub.cfg
   change "0" in line: set default="0" to your choice
sudo chmod -w /boot/grub/grub.cfg
Karim
  • 96
How do I set Windows to boot as the default in the boot loader?
This question was discussed previously and a detailed answer could be found here...
