On a fresh install of Ubuntu 11.04, running Unity, I can't adjust the brightness via Fn+Up/Down. The brightness panel will show, and increase/decrease accordingly, but the actual brightness never changes.
This is an issue I also had on 10.04. I used to fix this by adding this line
Option "RegistryDwords" "EnableBrightnessControl=1"
to my /etc/Xorg/xorg.conf in Section "Device". However it seems this is not working anymore. I also noticed the config file is much smaller that what I remember. Here is the whole file:
Section "Device"
Identifier      "Default Device"
    Option  "NoLogo"        "True"
EndSection
Should I use this line somewhere else ? or is there something else to fix ?
For reference, here is the original issue on 10.04: https://answers.launchpad.net/ubuntu/+source/xserver-xorg-video-nv/+question/109012
PowerKiKi
  • 954
i have same problem on dell vostro 3500 and solution from this question helped me to fix brightness bug: Screen brightness not changing on Acer 5742 notebook
The complete solution is:
  1. edit /etc/Xorg/xorg.conf to add the following line in Section "Device":
  2. edit /etc/default/grub to change the line into:
    GRUB_CMDLINE_LINUX="acpi_osi=Linux"
  3. run the command:
    sudo update-grub
  4. reboot
Novarg
  • 88
I believe you need to install Nvidia blacklight driver (nvidia-bl-dkms). The package itself has been developed for MacBooks, but they use same Nvidia model – G310M.
vartec
  • 7,085
