Screen brightness is not changing on my ACER 5742 notebook. I have Ubuntu 10.10 installed inside Windows 7 OS. Hotkeys are used for changing brightness. Though, a bar displaying brightness level appears on screen but there is no actual change in brightness of screen.
Suhaib
  • 4,171
This worked for me. Run:
gksu gedit /etc/default/grub
Change the line:
GRUB_CMDLINE_LINUX=""
Make it say this instead:
GRUB_CMDLINE_LINUX="acpi_osi=Linux"
Then run sudo update-grub and reboot. Credit to this guy.
Eliah Kagan
  • 119,640
Modifying both these lines in /etc/default/grub worked for my 4810T:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Eliah Kagan
  • 119,640
Daniel
  • 111
I had the same problem with my Acer 5749. The bar displaying the brightness would show that the brightness was moving up and down, but the actual brightness wasn't changing.
In /etc/default/grub, I tried just:
But it didn't work. Then I tried:
and that did work.
In both cases I edited the lines in /etc/default/grub then ran sudo update-grub and rebooted.
Another way, by editing just one line:
Finally I tried just:
and that worked too. I put the other line back to how it was originally and the brightness control still works after running sudo update-grub and rebooting again:
