When I try to install g++ in my machine I am getting the following message.
support:/$ sudo apt-get install g++
Reading package lists... Done
Building dependency tree
g++ : Depends: gcc (>= 4:4.8.1-2ubuntu3) but it is not going to be installed
Depends: g++-4.8 (>= 4.8.1-4~) but it is not going to be installed
Depends: gcc-4.8 (>= 4.8.1-4~) but it is not going to be installed
I am using Ubuntu 13.10(Saucy). I have stuck up with this problem for 2 days now. I know this is a duplicate question but still I am posting it because I couldn't find an solution from other similar posts.
I have tried all solutions given in Package system is broken. How to fix it? . But it couldn't solve the issue.
As asked in a comment in https://askubuntu.com/questions/385008/cant-install-g-on-13-10-dependency-problem , Im putting the result of apt-cache policy g++ g++-4.8 below
g++:
Installed: (none)
Candidate: 4:4.8.1-2ubuntu3
Version table:
4:4.8.1-2ubuntu3 0
500 http://de.archive.ubuntu.com/ubuntu/ saucy/main i386 Packages
g++-4.8:
Installed: (none)
Candidate: 4.8.2-1ubuntu1
Version table:
4.8.2-1ubuntu1 0
500 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu/ saucy/main i386 Packages
4.8.1-10ubuntu8 0
PS: I am not looking for any particular version of g++. Actual working scenario is I want to install npm package 'libxmljs' which is dependent on 'node-gyp'. For 'node-gyp' to install properly the system should have 'make', 'g++' and 'python'. I have make and python in my system. The following is what I get when I run g++ --version
The program 'g++' can be found in the following packages:
* g++
* pentium-builder
Try: sudo apt-get install <selected package>
Please help me to solve the issue.
