My laptop has pre-installed Windows 8. I want to install Ubuntu 13.10 alongside it.
Now I want only one boot option that is - Ubuntu. I want to be able to boot Windows 8 only from inside Ubuntu(through Terminal, most preferably).
Is there any way to do this?
mbtamuli
  • 103
You can run windows inside the Ubuntu only through the Virtual Machine.
Refer the following link : Install Windows 7 inside Virtualbox of Ubuntu?
Varun
  • 525
As far as I know, there is no way booting another OS through terminal. Except, you mean something like virtual OS.
If so, you can download virtualbox through apt-get and then setting up the environment.
Or, I found a way to boot already installed one, but this tutorial only tested in Windows XP. I already tried it and it works (Win XP). Here, take a look.
  1. Maybe, you can change the command as follow.
    sudo apt-get install virtualbox
    sudo VBoxManage internalcommands createrawvmdk -filename ./Win8.vmdk -rawdisk /dev/sda
    sudo apt-get install mbr
    sudo install-mbr --force myBootRecord.mbr
    sudo VBoxManage internalcommands createrawvmdk -filename ./Win8-ready.vmdk -rawdisk /dev/sda -partitions 1 -mbr ./myBootRecord.mbr -relative
  2. Then, start your virtualbox
    $ gksudo virtualbox
  3. Make new virtual OS.
  4. Set Type:MsWindows; Version:Win8; blabla then Next.
  5. Next again.
  6. On 'HardDrive' part, select 'Use an Existing...', click browse icon.
  7. Choose Win8-ready.vmdk on file browser.
  8. Then, create.
    Notice, all commands use super user authority.
Abdillah
  • 666
Refer this question
How to reboot into Windows from Ubuntu?
Basically you will be using your grub entries as a reference to reboot to Windows from inside Ubuntu. But this would still require to have a grub entry for Windows. Not sure if you can completely remove it.
Hashken
  • 6,340
