Is there a way to set a shortcut-key for copying a text format of current date and time of KDE environment's calender?
Why do you intend to use KDE Calendar for such a simple task? Why not to define a global shortcut
System Setting › Shortcuts and Gestures › Custom Shortcuts › Edit › New › Global Shortcut › Command / URL
for
date | xsel -i -b
You may use any imaginable date format if default (Fri Dec 20 09:33:37 MSK 2013)
 does not suite you, see date(1). E. g. date '+%F %T' will generate lexicographically sortable 2013-12-20 09:33:59.
Instead of xsel -i -b you also can use xclip -i -selection clipboard.
I assume you want to copy to CLIPBOARD. Use just xsel -i or xclip -i if you want to put date to PRIMARY selection.
    - 1,668
- 12
- 13
Thanks to Dmitry Alexandrov's answer above and wilf's answer, one can also set this command (as in answer above):
date '+%A, %Y/%m/%d  %H:%M:%S' | xsel -i -b && xdotool type '  ' && xdotool key ctrl+v BackSpace && xdotool type '  '
which will copy and then immediately paste a format of date and time. Hotkey 'F8' seems to be appropriate and works for me:
  Saturday, 2013/12/21  02:00:27 (other hotkeys may interfere with xdotool).
Copying KDE date and time format is unsolved yet.
    - 3,648
