I've downloaded a driver for a video card (*.run) and tried to install within a terminal. When I started the installation process I got this error: ERROR: nvidia-installer must be run as root. I'm logged in with my own profile.
Tim
  • 33,500
If you have an administrator account, simply
sudo command
runs commands as root after asking your password (for safety).
If your account is not an administrator account, you can't :-).
Notice: in a standard Ubuntu installation, the user you set up in the installation process is an administrator account. Guest account is not. Other users, depends on how you create them.
Notice too: "administrator" account in this context mean an account which has the privilege to become root. There is a lot more info in https://help.ubuntu.com/community/RootSudo and in https://help.ubuntu.com/community/Sudoers. I am using the simple "administrator account here" because it's how it's called in the graphic interface to create a new user:
Adding a user with administrative capabilities
Rmano
  • 32,167
