Newbee to Ubuntu.
I've just installed Ubuntu 14.04.
How do I log in as root? Alternatively, when performing su, what's the default root password?
Thanks in advance.
Asked
Active
Viewed 608 times
root, as a user, has a disabled password for your protection. To run a program as root, use either sudo or gksudo, if the program is terminal based or graphic based. For example, to edit your rc.local file, you would open a terminal and type gksudo nano /etc/rc.local
The password for performing items with the root permissions is the same password you logged on with.
There are methods for enabling "root" as a user - if you have a need for this, you will find the appropriate links.
Charles Green
- 21,859
