I've checked the question archive and can't find an exact answer to the following. I have just installed Ubuntu on a new PC.
While I'm fairly proficient in lumbering about in MSs operating console, obviously the Unix environment is quite different.
I need to run a command but when I su - to the root I am prompted for the password for permission to do so. This is the odd bit. When i enter the correct log on password it is rejected and I am returned to the same prompt from where I entered the su etc from. This is despite the password being the one that SUCCESSFULLY authorizes other system changes (such as installing new software like a virus checker etc). I can't get my head around this. It's the same password I created when setting up the system and, as advised, it allows root access in other ways, just not through the su - command.
Anyone help?
I have another question about mounting a volume but I won't ask that until I get this right as I will need to get to root to issue the command I suspect is needed to get this other matter sorted. Thanks in advance.
Peter
Since root login is not possible by default because of security concerns you can do
sudo su
or
sudo -i
in terminal(ctrl+alt+t). Which then asks for your user password. This will be accepted because youre in the proper group called sudoers.
Typing
exit
will bring you back to your normal user.
Videonauth
  • 33,815
