I want to create a shortcut key that toggles Airplane Mode On/Off, but do not know what command to use.
To create a shortcut I go to Settings> Keyboard> Shortcuts and then specify a command to be run whenever a given accelerator (shortcut key) is activated.
What command should be specified here to toggle Airplane Mode via a shortcut key?
Note that a while ago I asked a similar question, but the answer that I got back then can not be applied here, since a shortcut key command can not change between "on" and "off", but should truly toggle the Airplane Mode not just activate or deactivate it.
lindhe
  • 711
You can use the following simple bash script:
#!/bin/bash
wifi="$(nmcli nm wifi | awk 'FNR == 2 {print $1}')"
if [ "$wifi" = "enabled" ]; then
    nmcli nm wifi off
else
    nmcli nm wifi on
fi
Don't forget to make it executable:
chmod +x /path/to/script
Then add your custom shortcut to this script (it's up to you what shortcut want to choose - it should be something simple for you, like Alt+F5):
add custom shortcut
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Use nmcli radio wifi as nmcli nm is outdated.
Here is the updated script.
    #!/bin/bash
wifi="$(nmcli radio wifi)"
    nmcli radio wifi off
else
    nmcli radio wifi on
fi
