Setup
I have a fresh install of Ubuntu 13.10, with KDE (installed via Ubuntu server disk and sudo apt-get install kubuntu-desktop).
Problem
Whenever I suspend the computer while in KDE (either via sudo pm-suspend in Konsole or via KDE's interface), I get a black screen on wake up.
Attempted workarounds / fixes
If I press ctrl+alt+f1 and then ctrl+alt+f7 and I'm patient (20-30 seconds), I sometimes get back into KDE where I was, or sometimes I get back to the login screen (KDE crashed). But even when I get back into KDE, I get a notification saying that the special effects had to restart due to a graphics problem and then the fonts in all applications are... garbled.
If I suspend from another tty with sudo pm-suspend (while KDE is running on tty7), it works flawlessly (resumes instantly - no need to wait 20-30 seconds, KDE does not crash and does not cause font garble).
I tried changing graphics drivers and I get the same thing (I have Nvidia NVS300 and I'm using the latest proprietary drivers in Ubuntu repos). Also tried this Ubuntu freezes/crash after wake when upgraded to 13.10 and it didn't work.
This problem did not occur on the same system, when I was running Kubuntu 12.04.
Trying to find the problem...
Dmesg doesn't show any errors. I don't even know where to look further for any errors (any KDE logs?). Any help appreciated.
I found this workaround. I made a script that switches to console before suspend and switches back after resume.
I put attached script into dir /etc/pm/sleep.d. I gave it the name fix-black-screen and made it executable (sudo chmod +x /etc/pm/sleep.d/fix-black-screen).
#!/bin/bash
case $1 in
suspend)
    # Suspending to RAM.
    chvt 1
    sleep 1
resume)
    # Resume from suspend.
    sleep 1
    chvt 7
esac
Original fix found here.
I had similar problems to yours.
pm-suspend --store-quirks-as-lkw
Fixed my problems.
I only had to do it once, and suspending after that was working fine.
Give it a try.
I also have a machine with the latest nvidia driver and was seeing the same issue. I found that
pm-suspend --quirk-save-pci
seems to have solved the problem. I put it in my /var/cache/pm-utils/last_known_working.quirkdb file and I think it's working now.
Adobe
  • 3,971
Mitch
