I'm trying to use my Pi as a wireless Audio receiver. I read airplay is a good and easy way to do this, so I installed shairplay on my Pi. I can use the connected speakers via my Android smartphone with the app AirAudio.
Now I installed paprefs and pulseaudio-module-raop. The AirPlay is also shown as an Audio Output device, but there is no sound.
Can anybody tell me why Ubuntu doesn't send sound to my Pi?
Braiam
  • 69,112
user195780
  • 61
Unfortunately at present the raop module shipped with pulseaudio does not support the newer RAOP2 protocol for AirPlay via UDP (rather than TCP). This however would be needed to stream audio to ShairPlay or newer AirPlay devices.
There is some effort to implement a RAOP2 module for PulseAudio (see upstream bug #42804 and pulseaudio-raop2 at Git) but the work seems not to be finished yet.
Until then you may have a look at other streaming protocols to be able to send your audio to your RasPi (e.g. Bluetooth, Pulse Audio sound server, PulseAudio RTP streams, Icecast2).
Takkat
  • 144,580
Use native PulseAudio network streaming instead of AirPlay
Tune PulseAudio on your Pi
load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1;192.168.0.0/16 load-module module-zeroconf-publish Apply settings by restarting PulseAudio and avahi
Then enable "Make discoverable PulseAudio network sound devices available locally" via paprefs on your desktop
While using wifi connection to remote PulseAudio you will need disable bgscan https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/373680/comments/54
