10
I'm looking for a solution that would display the current mouse cursor coordinates in realtime (i.e. NOT xdotool and NOT xev).
I need to move the mouse to a certain position, then press Alt-Tab to flip to another window and record the coordinates there. (This would not move the mouse, so the coordinate display would stay the same).
There's a Windows program that works BEAUTIFULLY for this purpose - http://download.cnet.com/Cursor-Position/3000-2383_4-75449858.html?tag=mncol;1
...but it doesn't even start up in Wine.
Alternately, instead of displaying the coordinates, if this solution could copy the coordinates (in XXX,YYY format) to the clipboard, upon pressing a hotkey, that would be even better.
Any suggestions would be much appreciated!
P.S. I'm running Ubuntu 12.04 LTS.
user193844
  • 101
Spartan solution: you can show the coordinates in real-time with xdotool if you create a bash script. Just execute this in a new Terminal:
while true; do xdotool getmouselocation; sleep 0.2; clear; done
Change the value after sleep to make it more or less "real-time". This requires bash, the default user shell in Ubuntu.
Better solution: if you have admin rights, install watch (sudo apt-get install watch), and then execute this in a new Terminal:
watch -ptn 0 "xdotool getmouselocation"
It uses xdotool but does not require bash.
Thank you b_laoshi for your suggestion!
Get coordinates and copy to clipboard
Displaying the coordinates in real-time has already been addressed, so I won't repeat that answer here. By creating a script and configuring a keyboard shortcut to run it, we can copy mouse coordinates to the clipboard in x,y format. Here's how:
  1. Install xdotool for grabbing coordinates and xsel for managing the clipboard.
    sudo apt-get install xdotool xsel
  2. Create a new script file with the following contents. Save the script and make it executable.
    #!/bin/bash
    xdotool getmouselocation | grep -oP "[0-9]+ y:[0-9]+" | sed 's/ y:/,/' | tr -d '\n' | xsel --clipboard
  3. Create a custom keyboard shortcut that calls your script for the desired key combination.
b_laoshi
  • 4,868
  • 26
  • 49
A complete solution to show the mouse pointer location, based on xdotool getmouselocation like the other answers, to display the location in its own xterm terminal:
xterm -geometry 9x1+0+0 +sb -sl 0 -T 'Mouse location' -e '
  set -e; tput civis; stty quit "^[";
  while true; do
    eval $(xdotool getmouselocation --shell) && printf "%4d %4d\r" $X $Y;
    sleep .05;
  done'
(this can be written on one line if need be).
Some explanations:
  • The -geometry 9x1+0+0 puts the terminal at the top left, with the expected size.
  • The +sb tells xterm not to display a scrollbar.
  • The -sl 0 avoids an unnecessary scrolling buffer.
  • The tput civis makes the cursor invisible (it would be annoying).
  • The stty quit "^[" allows one to quit with the Esc key instead of Ctrl-\.
  • Concerning the sleep value, I find 0.1 too large; 0.05 seems OK.
vinc17
  • 196
